What method to brake pads last a long time?
What method of braking in daily driving will make the brakes last the longest? Short and hard or long and soft. (Yeah, I’ll leave that one out there for you guys). I’m guessing I’ll get a lot of “depends.”
I guess conventional wisdom is super light on the brakes for a long time before stopping, but I’m not sure that’s the right answer. Too long and it seems more like you’re riding the brakes. Too hard and that doesn’t sound good either. I guess it’s like that bowl of porridge for the blonde chick? I’m just curious. |
I have not done it but I've heard having the pads and rotors cryo-treated really increases their life span. Relatively inexpensive to have done. Apparently music places do it for guitar strings and some will do brakes for you.
As for technique I'd guess short and hard is the best.... Although I think the ladies prefer long and hard. |
I'm not an expert, but I would think the physics of stopping a certain amount of mass from random speeds would require the same whether you do it harder over a shorter distance or easier over a longer distance. I suspect the difference is how different people use/misuse their brakes. There are lots of people who touch and ride their brakes unnecessarily. I'm suspicious that's what shortens brake life for many. I live in a rural area, and see people riding the brake at random times. I've also seen people in town doing the same. I think it's a matter of managing your braking to reduce the amount you have to do, like going around corners & curves at a speed and in a way you don't have to ride the brakes in the corner or curve for instance.
The calipers are the expensive bit. You need to really stomp on the brakes and get them really heated up to burn off moisture and prevent rust and them seizing up. Changing out the pads is the easy bit.
Sorry to sound like a kill-joy but I had to replace the calipers on my SC and it was a major PITA, whereas if I'd given them some death in heavy braking situations instead of my usually mamby pampy braking they would have been OK. |
Just brake "normally" and don't worry about it.
If people behind you are freaking out and locking up their brakes trying to keep from rear ending you...Well, you are braking too late and too hard. If people are honking and going around you, or if in your rear view mirror you see them throwing their hands up (gesturing) and it looks like they are road raging, you are braking too early and too easy. And yeah, the brake pedal is not a foot rest. |
Quality pads will last. Cheap pads are cheap..
If you slow down over a longer distance, you give your cars natural friction/drag a greater percentage of the work. |
If you want your whole car to last longer, drive gently.
But your shouldn't "think" about making your brake pads last longer. Sounds obvious but just use them! |
There are quality levels of ceramic/titanium/unubtainium for both. Friction=heat=delamination=or? One of the surfaces has to give way first unless it's 100% hybrid regenerative air gap. As a basis: BMW pads are especially messy and spray carbon all over expensive wheels. Every single BMW high end car I've ever seen is covered with brake dust. |
The first thing I did when I bought my BMW daily 13 years ago was get rid of the messy factory pads and replaced them with low-dust pads. I got 107,000 miles off the front pads and discs and 205,000 miles off the rear pads (rear discs still had plenty of thickness so didn’t replace). I even had one or two track days on those (low dust pads suck for track work, needles to say...). Low dust pads don’t have the same initial bite as the factory pads.
I just go easy on the brakes. I don’t do long, light applications which heat up your brakes and I don’t stab the brakes either. If I’m coming up on a light up ahead I touch the breaks briefly to start slowing the car down and let momentum bleed off (as Tervuren states above), Then as I get closer to the light I just brake normally. This method has gotten me long pad life on all the cars I’ve owned no matter the pad material. |
I have been trying to get it in my son's head that when he can see the stop ahead sign to start coasting. It's a hard thing to get used to if you spend your life in a hurry but it's a lot easier on brakes.
As others have mentioned good quality pads make a difference. |
I believe I read that if you lift off the pedal in the middle of a stop for two seconds, it will lower rotor temperatures substantially. Sometimes I will brake a hair early for a light on a 45 to 50 MPH road, then lift and brake again. I will only do this if I know I will be stopped at the light before it turns. The smartest thing you can do is anticipate a light. If you can adjust your speed and lift off the throttle really early when approaching a light, it may turn green before you hit it, and you may be able to coast through at 20 or 30 MPH. The contrast would be to race up to the light at 55, hit the brakes hard, and come to a complete stop just as the light turns green. Now you have heated your brakes, worn on the pads, and lost all your momentum, forcing you to waste gas just to get up to speed.
There are plenty of places where you know you are going to have to stop, like at the tolls and at signs, where you can easily get off the throttle and coast up for a long distance, while really maintaining a lot of speed, even as you slow down. If you drive the same route every day, you can soon learn where these places are, and how to take advantage of natural slopes and gravity. There is one toll I come up to where I can be going 60, coast for a half mile, and still be doing 50 as I start to come up to the booth. There is another place where I go down a long hill to a stop, and I let the car have its head, because even if I pick up speed, there is a hill rising up to the stop at the end. I can hit the brakes moderately hard for a short distance as I hit that rise, then let gravity slow me further before I apply my brakes again. I think you have to anticipate, know your terrain, and look at the whole picture of using terrain, momentum and drag to get the best out of your circumstance. Like hypermileing or anything else, it is just a game to get your best. |
Thanks folks. I'm not actually planning to change the way I drive to try to make my pads last longer. This is more of an exercise about what's more pad efficient when you are using the brakes. Or, what if you were on a 2000 mile road trip and the pads hit the wear indicator, and you wanted to try to get home to change them.
Heat is the enemy. Overheat rotors and they warp. Overheat pads reduces life. Don't ride the breaks and don't do panic stops at every light. I know some folks will use staying in gear going down a big hill to save on brakes. I'd rather do a brake job than a clutch or trans job.
Deal is with the 911 it's nice to have the big grab when you need it, optimally, when you are planning for it.:) If you change compounds, the same wear rules apply. Although, ceramic will last forever with compromised stopping power vs organic breaking down much faster with better stopping force. I think factory pads are pretty hard (my fronts have lasted a long time). I upgraded to the Boxster calipers 10 years ago in front and those factory pads don't wear much either. I am not Bill Verburg with respect to brakes, but on the upside, I am just rambling.:D Hope you all had a good weekend. |
{PFFFFT! Everyone knows you just throw several downshifts prior to any braking. Transmissions last waaaay longer than brakes.}
Green font intended. Nothing to add other than I have always used quality rotors and pads and haven’t ever suffered poor brake life. |
Down shift and engine brake.
Google 'Bedding brake pads' and follow the instructions.
Beyond that, why worry about preserving the cheapest part of your car? I would never add clutch cycles to save my brakes. |
manual transmission...'nuff said
Maximize the amount of time your foot spends BETWEEN the gas and the brake.
A couple observations, from a more technical point of view.
It doesn't make much difference for the average driver. The rate of pad wear, relative to the amount of work being done, doesn't really vary much until you get to much higher temperatures than you're going to see in a normal stop. Lighter braking saves a little wear, because: Some of the braking comes from aerodynamic drag. As this rises with the square of the speed, you get more drag when you first start slowing down, so let that take care of the initial speed reduction. Add more brakes as you go slower, since the drag will drop fairly rapidly with the drop in speed. I could make similar comments with respect to engine/driveline drag. JR |
KNS has a great suggestion.
I learned the hard way. Wife's Q7 (we bought new) has always been a pain to keep the wheels clean. Organic pads - and was always dirty. Only went 35,000 miles or so - and needed all new pads and rotors. My opinion is that a modern vehicle should go 2x that before pads. Replaced them with (ATE, if I remember correct) rotors and ceramic pads. Lots less dust than the OEM, and I am hoping for better life. By the way - would have much rather changed the pads when new than need to do the full deal this soon. Getting rear calipers off was a pain, due to type of screw (16 point) and location / torque required. ***New parts came from Pelican, by the way. |
Some cars eat brakes, some don't.
My furd f150 has 93k on the original pads. The fronts are just about due, the backs are good for anuther year or two. A long time ago the wife had a plymouth voyager. POS went through front pads and rotors every 15k miles. Evidently they used the same undersized crappy brakes from the neon on the voyager. there's an empty jail cell waitin for the idjut who came up with that idea. The day we traded it in I made a note to self, never ever buy another Chrysler product. No matter what. I haven't and I won't. |
If it's a 4 door, convert the rear doors to suicide doors and have them open when you want to slow down. Then just a tap on the brakes and they should close.
In my truck, I went 3-4 years typically on a set of brakes. Lots of driving around town and being able to anticipate stops well in advance. I usually put no more than 20 miles on the vehicle per day. I probably had to panic-brake no more than once a year.
The year I lived in Atlanta I went through a set of brakes in just that year. Stop-and-go driving to and from work, 50 miles in a day. I had to panic-brake at least once per day. |
Break pad wear is right up there with worrying about zombies or invasion of space aliens for me.
I can order new OEM Mr. Goodwrench - AC Delco pad for my El Camino for $13 for the fronts delivered to my house. It is a 15 minute swap and done. The 911 pads cost more but even with an occasional track day and regular autocross events the pads last many years. |
It really works, I saw it on TV. http://forums.pelicanparts.com/uploa...1508785247.jpg |
Properly breaking-in brake pads is the single biggest factor for life and effectiveness of the pads.
For street cars as well as race applications. Lots of videos and googles for the subject. |
If you are mechanically inclined install a higher rear biased brake proportioning valve. Not equal bias to keep the emergency stops safe, but a little more than stock.
Honestly the best thing I have found to save my brakes is catch a ride with a friend in their car. Seems to help me save gas too! :D
Plan ahead... If you are looking ahead, you'll notice the ebbs and flows of traffic and can plan accordingly.. leave space around your car.. brake less... fwiw, on my DD, After 12 years and 210K miles I finally replaced the original front pads and rotors.. and there was still a backing plates worth of pad left.. I just knew they were glazed over and the rotors were not in good shape..
| All times are GMT -8. The time now is 04:35 PM. |
