-   -   Small engine part help (http://forums.pelicanparts.com/off-topic-discussions/975606-small-engine-part-help.html)
DWBOX2000 10-28-2017 11:20 AM
I have a push blower that a small hard plastic bushing broke on top of carburetor. A rod goes into the plastic bushing that goes into a hole on the carburetor. See picture. Where can I get a new one? http://forums.pelicanparts.com/uploa...1509214795.jpg
DWBOX2000 10-28-2017 11:21 AM
Any suggestions, I appreciate. Thanks.
RKDinOKC 10-28-2017 11:34 AM
Google is your friend. I have found a lot of obscure parts by searching for the device. motor brand, and part.
nota 10-28-2017 02:33 PM
lawn mower shop ? for the correct part !
or mickey mouse repair
get a hose about the size of the wire inside
and the hole in the bell crank outside dia [the brass looking thing with the hole]
secure with a wire hose clamp on each side
an auto parts store should have the hose and clamps
or whittle a wood dowel to fit the bell crank and drill it to fit the wire
super glue should hold it in place
do not forget to attach the spring wire the small wire in the smaller hole on the bell crank
JackDidley 10-28-2017 05:13 PM
They used to have a selection of plastic bushings at the hardware section at Lowes. I think they still do.
sc_rufctr 10-28-2017 07:57 PM
Would something like this work? (post pics of the original)
http://forums.pelicanparts.com/uploa...1509245810.jpg
sc_rufctr 10-28-2017 07:58 PM
http://forums.pelicanparts.com/uploa...1509245898.jpg
cabmandone 10-29-2017 04:49 AM
Looks like a governor rod and spring. How about a make and model for the engine? From there I'd guess I can find the clip. It should just be a round push in bushing.
asphaltgambler 10-29-2017 02:34 PM
If you visit your local auto parts store - there is a brand called 'Help' that reproduces small parts for automotive applications. There is also 'Dorman' who sells reproduction OE small items. These parts are typically non-wearing so no one has them.
You're likely to find what you need under those 2 brands - and/or adapt it to your situation.
