I think I would definately go with a gambrel roof as high as I could go for more loft space. I assume that the sq footage area is only the interior space ? I would then add a sloping lean-to off of one side for aditional, outside weather protected, storage.
I'd go with a gambrel style roof and a loft on one end. With 15 feet to the ridge you'd still have good storage room under the loft and have fairly accessible storage space in the loft.
The other option is to vacuum seal everything and bury it in the back yard. :D I saw that on an episode of American Pickers only the guy didn't vacuum seal the stuff. And I'd make a map of where everything is. |
Aesthetically, two identical 10x12 sheds might look crap, so that would need some thought... |
At my previous home, I had an 8x10 Tuff Shed. I had a slab poured first then Tuff Shed built it on that. They didn't use their floor. Had them anchor the walls into the concrete. Turned out great.
Nice pic's. I like a shed to be an asset to the place. Not an eye sore.
I need to build/buy a shed. I had been looking at converting a shipping container, but Imight do something a bit more stylish. We don't need consents for largish sheds if they are "removable" or on skids. |
Aesthetics are important to me too - I'd like them to be synch'd with the main house too (same shingles etc.). My comment about two sheds looking crap was not concerning general design, but the idea of having two "cookie cutter" sheds next to each other. I'd want some sort of asymmetry about them.
The layout of our back yard really only lends to them being next to each other on one side (with one in the back corner). The back yard is enclosed with a 7' fence, with neighbors to the side and rear. It would be great to build a simple 3D model of the shed in Sketchup and merge it into a GoogleEarth model of our yard. |
This all reminds me of the Monty Python skit about Arther (two sheds) Jackson.
Found a local builder and I'm going with a pair of 10x12s, with 8' interior wall height and gable-style roofs (about 11' to the peak). Although the gambrel would provide more loft space, I felt it looked a bit out of place in urban San Diego and I had to consider my neighbors with such a tall roof (even though the city allows more height). After some thought, I've decided on a simple block foundation, but with an extra skid and a thicker floor for rigidity. This will allow me to move them around if we ever needed to - plus access for slab equipment is very difficult in our yard and it's expensive!
This will be the general style - going to pony up for the paned doors and grid-style windows to make it look more house-style and repurposeable in future (office etc): http://www.outbackwoodproducts.com/i...-5wndos_lg.jpg |
Original structure went up in the 30's, properly permitted. In the 90's PO extended the back of the garage by a few feet. There was 100 ft of yard between the back wall and property line but what it did was make the entire structure fall under current building envelopes and we came within inches of encroaching along the side wall. Thankfully the inspector was a reasonable guy and purposely took his measurements at the widest point. |
| All times are GMT -8. The time now is 03:27 AM. |
