-   -   What size extension cord do I need... (http://forums.pelicanparts.com/off-topic-discussions/977395-what-size-extension-cord-do-i-need.html)
A930Rocket 11-12-2017 03:02 PM
I need to order a battery charger, trickle charger and extension cord for my son, while he's at school.
He rarely drives (2005 Tahoe) and the battery goes dead. The garage is detached, no power in it and probably 50-75 feet from the house. The house is downtown New Haven, there is no garage door, so theft is a concern.
What advice do you have on chargers and trickle chargers? I've got a 35 year old Schumacher that has served me well.
Would this be a good charger?
https://www.amazon.com/dp/B0009IBJCQ/ref=psdc_15707061_t1_B01KF9P5DM#Ask
Would this be a good trickle charger?
https://www.amazon.com/Battery-Tender-022-0185G-dl-wh-Charger-Maintainer/dp/B00DJ5KEEA/ref=pd_sbs_263_5?_encoding=UTF8&psc=1&refRID=BMQAE MKEDWE5VMJVTTS8
What gauge extension cord do I need? 16/2 or 12/3?
Bob Kontak 11-12-2017 03:05 PM
Secondary. All the step up is done inside the charger.
I would go with the 12 gauge as you may run a power saw with it.
LakeCleElum 11-12-2017 03:25 PM
I know 3 people that have burnt their house down with a battery charger/extension cord. One is an Ass't Fire Chief....
I have a lot of vehicles that sit in the off-season. Using caution, I charge each once per month, during the daytime when I'm around.......Their stories scare me...
cabmandone 11-12-2017 03:34 PM
This might sound a bit nuts but if he rarely drives it, why not pull the battery and charge it indoors? That or buy him a new battery?
BTW, yes on the battery tender. You could mount that one under the hood with the plug end sticking out the front somewhere and just plug in with an extension cord. I'd look at the breaker size for the plugs you're plugging into and size your cord accordingly. If you under size the extension cord you can melt the wires before the breaker pops. I'd say a 14 ga would be sufficient but a good 12 ga cord is handy for running power saws and other tools as well. Just something to consider.
RKDinOKC 11-12-2017 03:38 PM
Have ground fault on my garage sockets.
Still use the bigger cords and not typical lamp cords.
Bob Kontak 11-12-2017 03:45 PM
+1 I like those.
Side note:
My 1978 vintage Shumacher has a trip when excess amperage is pulled.
It works fine but it's 40 years old. What LakeCleElum says has merit. I would never walk away from that relic.
I do have a new big roller Schumacher that I will only set on six amps if I leave it overnight. It has 40 amp with a timer but I don't trust that much juice when I am sawing logs.
Battery tender - low draw and sophisticated shut down if required.
wdfifteen 11-12-2017 03:45 PM
Yep. Twelve guage cords aren't that expensive. May as well use them. The newer maintainers are better at keeping a battery alive - so I'm told. I have three of these.
SC1272 - Schumacher Electric
dad911 11-12-2017 03:47 PM
How about : Battery cutoff https://www.amazon.com/Swan-Type-Battery-Cut-Off-Switch/dp/B001JE32H4 so it doesn't discharge
And a jumper pack pack for emergencies?
wdfifteen 11-12-2017 03:50 PM
They self discharge. You don't need to have them connected to anything for them to go flat.
rockfan4 11-12-2017 03:52 PM
Okay, first, how long is "he rarely drives it"? I can let my 2010 sit for months and the battery has enough juice to start it. Same with the 2000 Ford it replaced. Both had remote locks, etc, the Chevy has remote start and it's not much of a draw.
Second, why not a solar battery maintainer? Better than running a cord all the time, save that for when you really need the charger.
Bob Kontak 11-12-2017 03:52 PM
If son can memorize radio re-enable code, if applicable, I like this too.
There may be the need for a root cause analysis. Parasitic amp draw or tired battery. This ten dollar upgrade will buy some time.
wdfifteen 11-12-2017 03:55 PM
A good battery will maintain a charge for months. A not so good one - weeks. The temperature has a lot to do with it. Without the maintainer the marginal battery in my mower will crank it only if it's over 30 degrees. It will crank at 20 if I keep it on the maintainer.
RKDinOKC 11-12-2017 04:39 PM
Solar maintainer doesn't do much good if the vehicle is garaged.
Evans, Marv 11-12-2017 04:44 PM
I just noticed Costco has the 3A Battery Tender for $30. I've had two of those on my tractors for almost eight years now with perfect service. That's on a 75 foot extension cord. It's not particularly heavy duty - somewhere in between. I did use one of those solar chargers for awhile, & it worked great. In my case, it was on the front of my tractor shelter. The wind moved the cord around, and it finally fatigued & broke.
A930Rocket 11-12-2017 04:50 PM
I'm guessing he drives it every few weeks. Probably more, but not very far. A trickle charger would be good here.
We got a new battery the summer of 2016, but it has randomly died sitting in the driveway at home. There must be a small draw that drains it every so often
He parks in the garage, so no solar power devices.
A930Rocket 11-12-2017 04:52 PM
He has no tools, but could buy them. He's just not mechanically minded like his dad.
It's an old house. I'll have to ask him about the breakers.
There will be no power tools used.
TimT 11-12-2017 04:55 PM
The box , think outside..
Get a solar trickle charger.. put the panel on the roof of the garage such that the panel get the best lights exposure...
Extend the wires from the solar panel to the car....
Bob Kontak 11-12-2017 05:02 PM
For the love of God. A lamp extension cord will do if a three prong with a modern charger.
Why not get an eight gauge extension cord?
The chargers have internal breakers.
Ever see a 110/220 mig welder video? They don't draw squat. It's the welder that steps up the amperage.
wdfifteen 11-12-2017 05:30 PM
A battery maintainer draws a tiny amount of current, a wet string would probably power it. You can use a cheap lamp cord and it will work fine if the run 12 or 15 feet, or spring for a good 12 ga cord if it's longer (I'm assuming they don't make long lamp cords). Any 15 amp fuse or breaker is more than an adequate power supply.
Bob Kontak 11-12-2017 05:37 PM
[QUOTE=wdfifteen;9812390]or spring for a good 12 ga cord if it's longer/QUOTE]
+1
Alternate uses down the road. They are expensive. $30-70 for good kit depending on length but the risk question is over.
