Data Farmer
Too many cooks in the kitchen
While reading the "lack of common knowledge" thread tonight, it occurred to me I don't deal well with "too many cooks in the kitchen." Subtitled- "too many chiefs- not enough indians." For example- in the common knowledge thread, the home owner cut off the water at the source, and the OP cut the water off at the tank.
Obviously, we know that the tank is the issue. There would be little risk at this point in turning the main water back on (for the toilets), but this was not in the homeowner's comfort zone. So for the OP- the issue becomes "politeness vs. the better common good of toilet flow." In this situation, I would have stepped back and let the toilets run dry, and then step into a highly attended group talk (filled with engaged group members who could not flush) with the obvious solution of turning the main back on with the hot water heater cut off, attempting to sell it as a low risk, win win option for everyone. I would be the right man, at the right place, at the right time, with the right idea.
But what a hassle. In all reality though- that's a lot of effort to gain a simple plumbing highground.
It reminds me of a situation the other week where I drove up on a car that had veered off the mountain down into a ravine below us. Several drivers (including myself) came upon the scene simultaneously. I offered to get my tractor to pull the car out. Another chief wanted to call a wrecker. Another chief wanted to use his truck to pull them out. Based on the car's location and need not to trash the neighbor's lawn, I felt my idea would be best, however, truck guy wanted a shot. He was the alpha male and was in control. He drove up and when he realized the slope, wussed out and drove off. I waited politely (passively aggresively perhaps?) until all the other "helpers" had extinguished their ideas. At that point, when asked, I reiterated my original idea, and gladly got the GT and pulled them back up to the road.
It's not just me either. In general, I work with a bunch of women, who can be caddy as hell, but overall do fairly well- BUT, when a bunch of know it all guys get together, who are used to working alone, have to build consensus, things go to hell real quick.
So basically, I like to be in charge, but I'm not there to get in a d#$ waving contest, and if it comes to that, I generally just walk. How do you guys deal with too many chiefs/not enough indians type scenarios?
Old 11-25-2017, 03:36 PM
fastfredracing's Avatar
Same as you. I walk, I hate to argue. I cannot stand this scenario, especially, when I know that I have got it, and have to stand and prove my case, when all I really want to do , is get the fking job done, and go home.
No left turn un stoned
Old 11-25-2017, 04:11 PM
Data Farmer
I'll give another example and then p$$ off...
Several years ago my father had (he still has it) a house that had fallen into disrepair.
On a front fascia, there was a lot of rot on a window sill. When my father left to get some food, I decided to grab his circular saw, make a guide, and cut out a section of the sill to make a groove, in which I could place an insert to remove/ fill the rotten channel, all without replacing the whole sill.
Unfortunately, the plan went to hell. My dad's saw had a dull blade, which burnt the wood more than cut it. Also- my dad (who was suffering from early dementia) had stored the saw outside, so the contacts were rusted, and it barely spun.
As a result, i was unable to cut a beautiful groove to insert a replacement piece before he and his helper got back.
At that point, all hell broke loose. To them, I had destroyed the house. My father wanted to use his "as seen on tv " $19.95 cutter to fix the situation. his helper, wanted to remover the entire window to remedy "my" mistake. All I needed was a working circular saw and 30 minutes. Neither of them were interested in my opinion though.
It was at that point my "step mother" called on her cell phone from 300 miles away demanding to know why I had ruined my dad's house.
With the local city department about to fine him bigtime for negligence issues, there were 1000 other projects that needed attention. Seeing that this was just a bunch of chiefs getting nowhere, I retreated to other jobs, where i could be more effective, however, to them it just appeared I didn't know what i was doing and scoured off.
To this day it pisses me off. All I needed was a working saw and 30 minutes, yet it turned into a total pissing match.
Arggghhhhh.....
Old 11-25-2017, 04:21 PM
Band.
PPOT is just a huge virtual kitchen.
But I'm sure someone has a better way to describe it
1983 SC Coupe
2020 Macan Turbo
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-25-2017, 04:37 PM
UnRegistered User
billybek's Avatar
Stand back and let things go to HE double hockey sticks then when no one is looking fix the situation and let them wonder what had happened....
Virtual kitchen. Ya, that's it...
Bill K.
Old 11-25-2017, 04:47 PM
