-   -   Javascript guru? Need what I think is easy help (http://forums.pelicanparts.com/off-topic-discussions/979081-javascript-guru-need-what-i-think-easy-help.html)
cstreit 11-28-2017 12:56 PM
Trying to run this script on a web page that sends some information to a Google API. The pertinent part is this: (removed script tags so it will post)
var email_addr = document.getElementById("EditBTAddres").elements["email_field"];
document.write (email_addr);
window.renderOptIn = function() {
window.gapi.load('surveyoptin', function() {
window.gapi.surveyoptin.render(
"merchant_id": 1234567,
"order_id": "Order ID",
"email": return email_addr,
"delivery_country": "US",
"estimated_delivery_date": "<?php echo date("Y-m-d", strtotime(date() . " + 3 day")); ?>",
"opt_in_style": "OPT_IN_STYLE"
My problem is - the email address is not getting sent. Instead it is sending "return email_addr" in the section hightlighted in red. Any ideas
stomachmonkey 11-28-2017 01:24 PM
"email": "return email_addr",
enclose return email_address in ""
Also, check the form they are filling in, is the field name / value return email_address or return_email_address
Note inconsistent use of underscore between return and email
EDIT: on a side note, try to be more consistent in your use of underscores and capitalization structure. You've got like 3 different styles for the same element. Pick a style you are comfortable with and stick to it, religously. Makes like a lot easier.
cstreit 11-28-2017 05:18 PM
Thanks. I'm just stealing bits of code. Most of that is Google's API standard code. I only added the first two lines.
So what I added was: var email_addr = document.getElementById("EditBTAddres").elements["email_field"]; because my form is named "EditBTAddres" (yes with the typo) and the field ID is email_field.
I'll try your suggestion. Thanks!
HardDrive 11-28-2017 05:48 PM
Oh how I hate javascript.
Dunno. I use the inspector in Chrome, throw in a bunch of debugging statements and step through to see whats happening. Not very helpful, I know.
stomachmonkey 11-28-2017 06:42 PM
That's what I suspected.
Actually it looks like your issue is what I said before plus the return.
Do this
"email": "email_addr",
You want that because you are looking for what the form is writing to the array.
