Senior Member
TV Antenna Question
I do not have 'cable,' but I do have a 55" flat screen Samsung TV and a Radio Shack antenna. The antenna has rabbit ears and a 9" loop thingie that looks like University of Oregon's logo. I can't find the (12V) power supply but if I find it, or can buy one, I wonder if it will work with this TV. I believe there needs to be a digital converter also, and I wonder if the TV likely has the digital converter circuit built in.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Just buy a Mohu. I have never had an indoor antenna that works so well.
'06 Cayman S '16 Cayenne '08 Audi RS 4 |
They also make outdoor digital antennas. I suspect with one of those, you probably would get a bunch more channels and all very clear. I'd love to put an outdoor up at my Mom's, but she's not allowed to have them where she lives.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
No, this is not a leaf model. It is the amplified "Curve" model and is designed for stations up to 50 miles away. I am on the fringe of 50 miles for my "local" stations and they come in solid and clear.
The old style "analog" work just fine as well, it doesn't have to be "digital" as that is just a marketing gimmick.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
There you have it, so your old rabbit ears should work just fine.
Just so you don't think I am shooting road apples:
HDTV Antenna Fact or Fiction FICTION Special HDTV antennas are necessary to receive the free over the air HDTV/Digital signal. FACT HDTV/Digital signal is and will broadcast on the same channel frequencies (VHF and UHF) that traditional analog television has been broadcasting on for years. The frequency band will be narrower covering channels 2 through 51. See: Real vs. Virtual Channels. There's no such thing as a HDTV antenna.
They were UHF until they dropped the analog signal and some went back to VHF which then became an issue for those UHF "digital" antennas.
Senior Member
I knew I could count on you guys. Thank you!
