1.367m later
Question for the expert mechanics here
My Dodge Dakota has about 20000miles on a total rebuild 4.7 w/automatic. It’s been running fine but recently I started getting a check engine light. Code reads PO305 (misfire detected cylinder 5 ). I’ve replaced the plug and the coil, and the injector. Compression is good. Still getting the light. At idle it feels fine but under light acceration you can feel a slight miss.
I’m at a loss as to what to do next. Any suggestions ? |
You do not have permissi
Precise compression testing is only as good as the accuracy of the test. This may vary with the test.
Oil can cover ring leaks up. I guessing those might not appear under idle/WOT conditions. Could it be: Intake manifold/gasket leak? Head gasket? Valve sealing? Sticky lifter? Particles in fuel line to cylinder 5? [disclaimer: not expert mechanic] |
Functionista
Only 20K miles? I’d check for rodent chewing through wiring also. Check that power is getting to coil..
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
one of gods prototypes
What's the fuel trim doing?
Brought to you by Carl's Jr. |
1.367m later
Start at the plug and work backwards. Have spark? Reliable spark? If not, go to the wire. Then to the coil. Then the wiring to the coil. If you've fired the parts cannon at it and it's still not working then I'm betting the wiring. The tiniest little nick can throw them off.
1.367m later
The only thing to do next ( that I can think of ) is to lift the valve cover and see if it’s a bad valve or lifter |
Functionista
So you’ve switched injectors with another cylinder and still #5?
Bad valve or lifter should show up on comp test. Did you leak down test engine?
No the lambda control..... any cheap scanner should tell you if its adding or subtracting fuel. "Fuel trim", it'll be a percentage reading. If it's adding fuel at idle range there could be a vacuum leak somewhere..... do you have a scanner?
1.367m later
Functionista
See if problem follows after switching injectors.
I would think a leakdown of that cylinder would be my next step. Aren't those early 4.7 motors famous for dropping the valve seats out of the head ? It is also possible that you have some abnormal cam wear. Easy enough to pull the valve cover, and make sure you are getting full lift .
No left turn un stoned |
1.367m later
I guess I’ll be removing a valve cover next. |
1.367m later
Make Bruins Great Again
Poor or dirty contacts with the coil wire can cause problems under load. Check to make sure the connectors are tight and there is no corrosion.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Senior Member
Flux capacitor.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Single cat exhaust? Might be a plugged cat. Has it been replaced over those 200,000 miles? Also, check oxygen sensor...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Gon fix it with me hammer
He only has 20 K miles
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Actually he has 20K on the rebuild and an unknown # of miles on the rest of the truck likely including the cats. But as the problem seems to indicate a single cylinder, then the cats are not a likely issue as that would impact the entire bank (or the entire engine if single cat).
I'm not a mechanic, nor did I sleep in a motel 6 last night. But I do seem to recall these engines would occasionally develop cracks in the cylinder heads. That could manifest as a miss that is not related to fuel or ignition issues. Really need to do a good compression/leakdown on this one. angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Still Doin Time
I agree with Fred - start with cranking compression, then leak down test
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
