-   -   Bitcoin transfer question (http://forums.pelicanparts.com/off-topic-discussions/981520-bitcoin-transfer-question.html)
seafeye 12-22-2017 09:43 AM
I tried to transfer bitcoins from my Gemini account to Coinbase.
I got the address from Coinbase and Gemini sent the funds. But they never showed up. Of course there isn’t anyone to contact. Where could these funds disappear to? Or are they just hung up? Can the transaction be cancelled?
https://www.smartbit.com.au/tx/9893d93668efabd31b34c49b9e78dd4c16e18fc1e085406b44 9ea0215318391b
https://www.smartbit.com.au/address/1GLde3TnMqYy4DdamPcCEFC47zH3rvwroB
Pazuzu 12-22-2017 10:33 AM
"Monitoring - Due to today's high traffic, buys and sells may be temporarily offline. We're working on restoring full availability as soon as possible. "
"Investigating - All buys and sells have been temporarily disabled. We are working on a fix and apologize for any inconvenience. "
"Update - Wire deposits and withdrawals may be delayed by up to 5 business days. Rejected & reversed wires will now be processed within 48 business hours. We apologize for any inconvenience this may cause. "
All within the past 48 hours
manbridge 74 12-22-2017 12:35 PM
Signs of uber hackers?
Skillet83 12-22-2017 07:51 PM
I did transfers from coinbase to bitstamp with conversions and back to coinbase from bitstamp a couple times today. Both times completed in minutes.
biosurfer1 12-22-2017 10:13 PM
Anything to do with coinbase in the past couple days runs the risk of being heavily delayed.
The Bitcoin block chain is also backed up with the selloff. Be patient, it will show.
Arizona_928 12-22-2017 10:43 PM
Coin base is iffy.
Being investigated for inside trading for that bitcoin cash deal
biosurfer1 12-22-2017 10:52 PM
Originally Posted by AZ_porschekid (Post 9858910)
Coin base is iffy.
Need to check your facts, they are the ones doing the investigating.
cstreit 12-23-2017 07:16 AM
Lots and lots of delayed transactions right now due to volume. My last payout from a pool took 16 hours to go through.
Arizona_928 12-23-2017 09:05 PM
eh close enough.
They're being investigated by themselves for insider trading. :D:D:D:D:D:D:D
seafeye 12-24-2017 09:47 AM
4 days later and still nothing.
seafeye 04-13-2018 06:37 AM
I finally got my funds yesterday. Of course bitcoin was at $17000 when I made the transfer. And now $6000. Don’t think I can recommend Coinbase. 4 months to make a transfer. Argggggg
biosurfer1 04-13-2018 09:14 AM
Now you see the drawback to Bitcoin and why alt coins are on the rise.
4 months means there was a big issue though.
Pazuzu 04-13-2018 09:30 AM
Were you converting to USD using Coinbase, or were you simply moving your wallet?
RedBaron 04-13-2018 09:43 AM
Just use the Square Cash app...
https://lifehacker.com/how-to-buy-bitcoin-with-square-cash-1822636235
I've noticed a lot of Square setups in smaller business, I think they are starting to become the next paypal IMO.
seafeye 04-13-2018 03:31 PM
I was transferring BTC to BTC. If it was to usd that would have been better. I did get this from Coinbase today. I don’t really understand the transfer protocol so much. But if they gave me an address. Shouldn’t it be valid?
We are reaching out to notify you that we recently credited your account for a previous transaction.
When the Bitcoin Cash fork occurred last year, it split the Bitcoin blockchain into two separate chains. After this point, some customers mistakenly sent Bitcoin or Bitcoin Cash to an unsupported address from the opposite chain. Because these transactions were not sent to the customer’s registered address on the relevant chain, the funds were not credited to their Coinbase account.
One or more of your incoming transactions was sent to an unsupported address that was not registered to your Coinbase account, and thus was not credited to you at the time of the transaction. As a courtesy to our customers, we retroactively added support for these transactions and credited them to your account.
As the cryptocurrency industry evolves, new blockchains will continue to emerge and could cause confusion about which address you should use for your Coinbase transactions. Coinbase does not support any asset being sent to the address for a different asset. Any funds sent to the incorrect address will be lost.
You should always be sure to use an address which has been generated for the specific asset you are sending. You can view these addresses, or generate a new one, by visiting the Addresses page in your account tools.
Thank you for using Coinbase,
The Coinbase Team
biosurfer1 04-13-2018 04:24 PM
Looks like you tried to send BTC to a BCC wallet and it wouldn't go through, it was in limbo until Coinbase added functionality to cancel the pending transaction. This is a big problem with forks since they use the same wallet naming convention. Consider yourself lucky, there are times when if you do that, it's lost forever.
34 BTC is still a good amount to have. I would suggest holding onto it, especially considering the past 3 days activity.
