-   -   Question for the PP brain trust: Explosive removal (http://forums.pelicanparts.com/off-topic-discussions/982967-question-pp-brain-trust-explosive-removal.html)
Mark Howard 01-04-2018 06:52 PM
Hello all. Hopefully you guys that can think way out the box can assist. So I bid on, and won this contract with the government...not really “explosive removal” in the EOD sense...but involves inspecting and clearing cotton bags of M6 powder.
Background: an explosive de-mil company abandoned 1.3m “Redbags” - these cotton bags filled with powder used to propel artillery shells out of the barrel down range. The bags contained Clean Burning Igniter, black powder, and M6 pellets. The de-mil company was harvesting the M6 and reconfiguring it to sell to the mining industry. Things went badly for them so they just abandoned everything.
My challenge involves conducting a 200% inspection of each bag, by hand, before they can be sent to the landfill. I’m trying to determine the most efficient way get inside the bags to inspect them. The bags are 18” long, about 6” diameter, and cut open on one end. The cotton is rather stiff as the insides are lined with a lead foil. We are only looking for M6 pellets will be hiding in the seams at the end of the bags. They are about the size of a cigarette butt.
We have considered cutting lengthwise and opening, cutting the closed end off, or using a mounted pole to push them on to turn them inside out. The issue of efficiency concerns safety and fatigue on the part of my workers...I need the safest and best production throughput for the least amount of physical effort. All other PPE will be work for the lead hazard, so I got that solved.
Any thoughts?
Attaching pics of the mess.
http://forums.pelicanparts.com/uploa...1515120700.jpg
john70t 01-04-2018 07:19 PM
My first guess:
Automate the system as much as possible.
Worker forklifts it up on table next to gizmo (with osha autoshutoff features of course. maybe based on amp draw.).
Another worker takes bag head and places it on gizmo cone.
Gizmo grabs sides and pushes bag inside out over a pit.
Another worker takes bag, checks, and drops it into laundry basket whatever to go on the truck.
Workers screened and everything recorded so their next July4 doesn't get out of hand.
SCadaddle 01-04-2018 07:21 PM
Mount you a frog gig pole with the gig pointed upwards, place the open end of the bag over the gig, pull down until it is gigged, pull up to turn the bag inside out, inspect, ungig, repeat.
LWJ 01-04-2018 07:21 PM
What happens if a pellet is smashed? I think using a shear to cut lengthwise would facilitate an easy inspection?
I don't know what would happen if the shear hit a pellet. Might be bad.
Good luck.
Larry
Bill Douglas 01-04-2018 07:26 PM
Make a condition of employment that they are non-smokers :D
Mark Howard 01-04-2018 07:30 PM
Excellent, I think you’re on to something there. Maybe place them over a pvc pipe or cone and have a pneumatic plunger push the bag through the pipe out the bottom turning it inside out?
Mark Howard 01-04-2018 07:32 PM
The pellet is rather inert until you add fire...but they have to be under compression to explode. They are only a flammable solid otherwise.
Correct, smoking is not authorized.
stomachmonkey 01-04-2018 07:32 PM
Guys, he said 1.3 Million of those bags. :eek:
He needs as automated a solution as possible.
How explosive is an M6 pellet, as in, firecracker, M80, stick of dynamite? And do you need recover it?
If you don't need to recover it and a few pellets don't pack a bunch of punch I would get a big ass steam roller, lay the bags out, run them over crushing the pellets, then wash the bags while inside out.
That's all I got.
Good luck.
john70t 01-04-2018 07:38 PM
Only problem with moving/mechanical things is that people tend to stick body parts in it.
Could they be crushed and incinerated?
You could sell them as fuel. lol.
lendaddy 01-04-2018 07:44 PM
" So I bid on, and won this contract with the government..."
http://www.showbiz411.com/wp-content...8/war-dogs.jpg
fanaudical 01-04-2018 07:46 PM
Total long shot (assuming you have the means to pull this off):
How thick is the lead foil on the interior?
If less that 0.5mm thick total, you may be able to place bags on a conveyor one at at time and have them X-rayed with commercial inspection equipment. Only open/empty those with detected pellets.
Alternate idea:
Set up a table with a catch bin and concentric to that bin place a chunk of pipe with an air nozzle pointing straight up. Worker grabs open end of bag, pulls it over air nozzle, hits foot pedal to turn on air. Air inflates bag, dislodges pellets, pellets fall into bin.
cstreit 01-04-2018 07:49 PM
Can you run them through a metal detector or x-ray and measure the output?
fintstone 01-04-2018 07:59 PM
Use open burning of the bags in burn trays. Materials are destroyed by self‐ sustained combustion after being ignited. They would not be confined and therefore would not detonate. Recycle the lead. Put ashes in landfill.
Maybe subcontract out ESI who did this at Camp Minden.
https://www.epa.gov/la/camp-minden
aigel 01-04-2018 08:01 PM
How thick is the lead? I would check into x-ray inspection if the lead is thin enough to make it absorb less than the C6 pellets, you will be able to see the pellets. You may be able to rent equipment used in industry applications such as chemical engineering or even TSA type machine with a conveyor belt. In Louisiana you should have plenty of options with the chemical industry as xray is used for a lot of inspection of pipes, reactors etc.
1.3 million - man - that's going to take a year if you don't work it in parallel and one bag is 5 seconds.
G
MBAtarga 01-04-2018 08:04 PM
Will you need to remove/recover the lead or does that go in the landfill as well?
I'd suggest low pressure/high volume air source available in front/above the worker. Worker opens bag and air source inflates the bag. Worker than plunges the bag over a cylindrical pipe/column essentially turning it inside out. Any pellets remaining drop out and below which can be collected in a basin which surrounds the pipe. This also leaves the lead foil (liner?) exposed/external if needed.
aigel 01-04-2018 08:05 PM
Haha, fanaudical beat me to it. A bright lamp may also work?
G
lendaddy 01-04-2018 08:08 PM
"200% inspection of each bag, by hand"
If this is in the contract you're rather limited. One of your initial ideas, punching the bag inside out via (semi)automation, is where I would start. A simple 200% hand swipe after that would satisfy the language above while being effective.
Mark Howard 01-04-2018 08:13 PM
Lead foil is very thin, like a tape. The 200%inspection has to be visual, according to DOD, so X-ray probably would,be a no go, and probably complicated to sell the concept to the site manager.
Flint -can’t burn anything. There is a local community action group that is crazy about this stuff, somewhat rightfully so. Incineration was proposed and denied by the owner.
I like MBAs proposal, just need to find a mechanical company that could design the system.
My proposed production rate is 4 bags per person per minute. 25 pax puts that at about 48k bags a day through the system max, not being 100% efficient, I’m figuring 30k a day with my current crew, about 2 months of work....sucky work.
HardDrive 01-04-2018 08:39 PM
Buy a bunch of shipping containers. Drill big holes in shipping containers. Stuff them full of this crap. Put shipping containers on 3rd rate container ship from 3rd world country. Pay crew to ensure that said containers are 'lost' in a storm in the mid atlantic. Profit.
(Just so no one gets their panties in a knot, I'm kidding.....)
cstreit 01-04-2018 10:02 PM
Don't forget about insuring the merchandise and contract against such losses ahead of time. :D
Jim Bremner 01-04-2018 11:11 PM
emersion in water?
Willem Fick 01-05-2018 02:08 AM
Send them to me!
I'm in a third world country where labour is cheap and lead expensive! SmileWavy
GWN7 01-05-2018 05:19 AM
Not knowing anything about M6 I went to the net and found this:
"Explo Systems left 7,800 tons (7,100 metric tons) of M6 and 160 tons (145 metric tons) of clean-burning igniter at Camp Minden when the company went bankrupt in 2013.
Louisiana State Police had begun investigating the company in 2012, after the explosion in one of Explo’s leased bunkers and a nearby trailer shattered windows 4 miles (6 kilometers) away in Minden and created a 7,000-foot (2,130-meter) mushroom cloud and derailed 11 rail cars near the bunker.
The bunker had held about 62 tons (56 metric tons) of smokeless powder and the trailer had held about 12 tons (11 metric tons) of demilitarized M6, according to a news release from the U.S. Attorney’s Office."
https://www.insurancejournal.com/news/southcentral/2017/12/20/474922.htm
It appears the safest way to dispose of the bags is to burn them. I know you said that it is not allowed but disposal in a commercial burner would be the safest way and would allow the recovery of the lead without contaminating the area. Not to mention the M6 can be set off by impact force. There is also the 160 tons (145 metric tons) of clean-burning igniter that is also there.
Mark Howard 01-05-2018 06:20 AM
GWN7 did indeed find the article that started it all. All the bulk M6 and CBI is gone, has been incinerated in a state of the art incinerator. The residue M6 is a di minimus amount in these bags. Other firms bidding proposed incineration of the bags but were refused.
MBAtarga 01-05-2018 07:44 AM
I'm off to file a patent right now!
dad911 01-05-2018 07:50 AM
Originally Posted by Mark Howard (Post 9872864)
My challenge involves conducting a 200% inspection of each bag, by hand, before they can be sent to the landfill. I’m trying to determine the most efficient way get inside the bags to inspect them. The bags are 18” long, about 6” diameter, and cut open on one end. .......
Put each bag over a tube, with a camera. 2 people monitor the video?
Does it make sense to throw them on a digital scale after inspection, in groups of 10 or 20, to double check?
dad911 01-05-2018 08:47 AM
I missed that. Good idea. leaf blower or shop vac would likely do it, but noisy. I'd try a duct blower/bilge blower.
Or maybe zanick is closing out some eRAMs?
fintstone 01-05-2018 09:20 AM
The air system is a good idea. Build yourself a manifold from home depot parts like this:
http://forums.pelicanparts.com/uploa...1515172173.jpg
except make it on a larger scale. Might be able to use PVC. or more expensive galvanized. Make each pipe coming off the main line the exact right size for a fairly snug fit on the bags so they inflate but do not blow off. Control the air with a valve. A worker puts a bag on each pipe coming off the manifold...could be very many at once. Inflate the bags and then turn off the air and vent it. Any M6 pellets will fall down into the main manifold when the air is removed. Remove the bags and use a quick burst of air to blow any pellets out if the main pipe. Repeat.
herr_oberst 01-05-2018 09:26 AM
Tell your workers that there's a trip to Tahiti and a brand new Ford F150 pickup for the person that finds the tiny token that you've hidden inside one of the bags. Got's to keep 'em motivated.
MBAtarga 02-14-2018 07:44 PM
So did you come up with a solution?
John Rogers 02-14-2018 08:15 PM
Did you try the GOEX or Hogdon companies as they are the black powder folks located in LA? If you were in AZ or NV you could take them out into the desert and set each tri-wall on fire, watch the bang then repeat.
FPB111 02-14-2018 08:45 PM
I worked for Hercules during the Vietnam war. We made military powders, M9 and other MIL spec powders + dynamite.
All dry powder handling operators had conductive shoes and all equipment had ground straps to preclude static caused explosions. The lights and other electrical equipment was outside of the building where possible inside everything was explosion proof. In drying houses the lights shined in through the windows.
Think about static if you use bags sliding over PVC.
svandamme 02-15-2018 12:02 PM
hire 10 foreigners that smoke.
Be elsewhere when they work.
