-   -   Is there a quiet air compressor? (http://forums.pelicanparts.com/off-topic-discussions/984321-there-quiet-air-compressor.html)
widebody911 01-16-2018 12:47 PM
Interesting Evaluating True Horsepower and CFM Ratings of Air Compressors
Charles Freeborn 01-16-2018 04:18 PM
If you put in a box you’ll need to force vent it or it’ll overheat. Look up “Rotary Vane Compressor”. Not cheap, but dead quiet and very high output.
Quincy makes a fine unit. https://www.aircompressorsdirect.com/Quincy-4152002723-Air-Compressor/p10831.html
look 171 01-16-2018 05:38 PM
You guys know damn well that California air compressor ain't gonna run no air tools. A air brush or a finish nail gun, that it.
A930Rocket 01-16-2018 05:52 PM
That's the brand I did a search on. Very quiet.
The dry system is less than 100 gallons, so a small compressor that kicks on every so often will work.
Originally Posted by Danimal16 (Post 9887819)
Have you looked at California Air Tools? California Air Tools
I have this one (which is much smaller than you require):
https://www.amazon.com/gp/product/B00TDNKBMC/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
It is a great little QUIET unit.http://forums.pelicanparts.com/uploa...1516119989.jpg
Danimal16 01-16-2018 07:21 PM
It fills tires. Not much more. Not designed for heavy use. It is aluminum and easy to transport.
I use battery impacts. For high output I use PowerTank.
Now with all of that said, read the original requirement. Does not include high consumption tools.
reed930 01-17-2018 04:08 AM
My recommendation? Stay away from oil less. Not only are they objectively louder, their sound quality is much "harsher" than an oil type. I've owned the Makita MAC700 for years, and it's a powerful little workhouse. Decently quiet and trouble free.
KFC911 01-17-2018 04:27 AM
Nonsense....I have a large tank in my garage, and picked up a small tank compressor for flooring projects and wanted something portable years ago. I don't use air tools that require a constant flow usually, so my small tank does great with all my nailers, powerful impact wrench, etc....90 psi is all that matters....rarely do I use my large tank any more...
Porchdog 01-17-2018 08:17 AM
I have used isolation feet under the compressor which helps. The big improvement I have made is to fab up a hose adapter and use radiator hose (and tube if it is a long run) to pipe the air inlet outside and put a protected air filter outside. That move most of the noise outdoors, which may not thrill your neighbors.
With the popularity of "cold air intakes" I have seen custom intake "kits" at the auto parts store, which might be easier than my solution with radiator hose.
You can also use compressed air or nitrogen in bottles for your dry system but there are some code requirements for monitoring pressure.
