-   -   Wheel lock socket lost — I could post in several forums...but... (http://forums.pelicanparts.com/off-topic-discussions/991428-wheel-lock-socket-lost-i-could-post-several-forums-but.html)
onewhippedpuppy 03-23-2018 04:34 AM
Dealership, it’s an easy answer. That’s an OEM Porsche wheel lock, they will have the key.
matthewb0051 03-23-2018 11:15 AM
Looks like that Gator socket may work.
I had similar on our Land Rover LR4. It had those locks with the wavy center. The wavy center on the key broke loose and became useless. I ended up driving on the smallest socket that would fit with a hammer. Ended up sacrificing a few sockets but it worked.
No more locking lugs for me. That was the biggest waste of time.
masraum 03-23-2018 11:34 AM
As suggested, go to the dealer and they'll pull that right off.
But, I had some cheap lock nuts on a Ford Ranger that I bought many years ago. I worked with a kid that was reformed, but had been a hoodlum when he was <18. He told me the secret for my lock lugs was to get a Craftsman 6 point socket (11/16 maybe?), drive it on with a hammer and then take it off with a breaker bar. It worked like a charm, and being young and poor means that I abused the Sears warranty a little bit and just exchanged the sockets with the nuts wedge in place for new sockets.
DanielDudley 03-23-2018 01:03 PM
https://www.ebay.com/i/111335680742?chn=ps&dispItem=1
Been told to drive a 17 MM 12 point over it and remove.
356racing 03-23-2018 06:43 PM
I have removed those same locks by hammering a 15/16" 12 pt socket over them and then backing off with an impact. Takes a few seconds, nothing to it. Once the wheel is removed, thread the bolt back in and knock the socket off. Learned the trick from a buddy that worked in the Sears tire shop during college, they had a near limitless supply of 12 pt sockets!
smadsen 03-23-2018 09:32 PM
Search youtube. There's a half dozen videos on the subject.
You need a sacrificial deep socket from Harbor Freight the next size smaller than what will go over the nut/bolt. Install with the ubiquitous BFH. I'd use a breaker bar with a cheater pipe over the rattle-gun approach. A little more dainty.
masraum 03-23-2018 10:16 PM
Yeah, Breaker bar, but when I did it with craftsman the deepwell didn't work, but maybe that's because it was a craftsman 6-pt vs a cheapo 12-pt.
sc_rufctr 03-23-2018 11:38 PM
http://forums.pelicanparts.com/uploa...1521873518.jpg
wdfifteen 03-24-2018 10:38 AM
Nice to see you stop by now and then Zeke/Milt. I always enjoy your input and hearing about your projects.
That's all I've got. I can't help with your wheel locks (has anyone mentioned explosives)?
pwd72s 03-24-2018 11:23 AM
Originally Posted by sc_rufctr (Post 9973506)
5-pc Lugnut Specialty Set - Tools - IRWIN TOOLS
Wangrande 03-25-2018 12:50 AM
You know everything. You have the answer.
rfuerst911sc 03-25-2018 05:40 AM
Milt I had the same problem on my 986S , previous owner lost the " special " key/socket . As mentioned by others take a 15/16 socket preferable a 12 point ( more teeth ) and lightly pound it on . Do the security bolt on each wheel FIRST then the others . You only have to break that initial surface tension then they will come right out . The best part of this project is the noise each security bolt makes as you hurl them across the garage into a metal garbage can :D
I bought 24 used wheel bolts , four to replace the four I tossed and twenty as spares . Eventually one set will be painted silver the other set black because I have two sets of wheels . No more security bolt B.S. :mad: If a professional thief wants your wheels he'll get them . If he can't get the wheels off he'll just steal the car ! Good luck getting them off .
Zeke 04-09-2018 08:19 AM
Just a quick update for posterity. Thanks to the suggestions I used a 12 point 15/16" socket driven on with a hammer. Might not work if your bolts are over tightened but at the correct torque, the bolts gave up easily. Same socket lasted for a 4 bolts.
You will need a deep socket for the rears or an extension. I used a standard socket that was not a particularly 'known' brand. It's called "Fleet Tools" but it's still intact. FYI Fleet was made under the Proto umbrella of companies so I guess it is better than some import junk. Bear that in mind when selecting a socket and maybe if you have to do this it will go as well as it did for me. 2 minutes a wheel.
Thanks to all that commented except those that would have had me go to a dealer. Too easy for that.
fastfredracing 04-09-2018 08:46 AM
When is the last time any of you have honestly heard of a set of wheels being stolen ?
I gotta say, it has been a really long time for me . These are the thoughts that go through me head, when see wheel locks any run of the mill vehicle .
If I buy a car that has em, I toss em in the trash , and replace with an oem nut. If it is a special car, I will save them, but not use them.
Of course, I live in an area where it would be highly unlikely to have anything stolen like this .
Now that I mention it. The local independent dealer, did have a set of wheels stolen from a Bentley last year. I think they were huge money , and it all stunk of an inside job when I heard the story, but oh well, what do I know ?
Gamecock 04-09-2018 08:58 AM
Funny, that's a timely thread.
I just took my recently-acquired 958 into my local Indy shop for a brake job. They called me saying they couldn't find the lug nut key anywhere. I told them I thought it was in the glove box but wasn't sure, they assured me they had checked everywhere and couldn't find it.
They ended up driving it across town to the Porsche dealer to get the nuts removed. Rather than order a new key, I asked them to just replace the locks with proper nuts.
Go to pick it up and they toss me the locks in a plastic bag with the corresponding "key" number "just in case you want to order a new key".
When I get home, I toss them in the glovebox...and what do I see but my missing "key". :rolleyes:
Baz 04-09-2018 09:00 AM
Thanks for the update, Milt - glad it worked out....good stuff!
onewhippedpuppy 04-09-2018 12:30 PM
Nice of you to piss on the common sense advice that people were nice enough to offer. Had your wheels been overtightened by the last tire shop to touch them, you'd probably be singing a different tune. There's not much to bite on the outer diameter of the OEM wheel locks, it would be VERY easy to just spin a driven on socket on a tight nut.
Zeke 04-09-2018 01:20 PM
Advice to go to a dealer. Well, first of all that would be an OBVIOUS solution. I probably wouldn't have asked the board if I was going to go to the dealer. No, what you really meant was take the easy way out and let your wallet do the work.
Instead, I took 15 minutes of a Sunday and did this myself. Seems to me that the theme of Pelican Parts forums is DIY and is supported by our purchases. Telling members to go to the dealer is a disservice to Pelican.
However, before I clicked 'submit reply' I called a local dealer. Service dept wanted nothing to do with this. The service guy said that I should approach the parts dept about the master keys and then buy one after locating the correct pattern. Why would I buy a replacement if I'm tossing these? What's more is that I wonder if they will let a customer take the set out to the parking lot. I'll never know.
My fault for not checking for the key when I left the tire shop with new shoes but no key. That was a while back in itself, so going back there complaining would be a waste.
masraum 04-09-2018 01:31 PM
I have a buddy that lives in a fairly nice/decent neighborhood. Over the holidays, several trucks in his neighborhood were left on blocks.
Jims5543 04-09-2018 01:35 PM
Ooops I should have read to the end. I was excited to share my experience / hack.
I had lug locks and no key on a car I purchased years ago.
I spent the big $$ and bought a removal socket and it worked like a dream... once.
After one use it would not work anymore.
Then I took a standard socket that would not quite fit over the lug, in this case it turned out to be a 3/4" socket. I hammered the socket over the lug and with a long breaker bar I was able to gently break the lug loose.
I thought I may be able to knock the lug out in a vice, no joy, I went to the Ace hardware and purchased 2 more sockets (still cheaper than the removal socket) and repeated 2X.
My 2014 i3 has lug locks too and no key and no spare, I will let BMW deal with it if I ever take it in for service.
