hemp rope ROTS
Dacron will last many years |
^^^yeah, I had a feeling. I will post up my latest vision, later. A hybrid of sorts.
This is what I did years ago with chains and trees that were much bigger and it had a lot of sag with me on it.
The kids did pretty good though. http://forums.pelicanparts.com/uploa...1522164382.jpg |
Cut down the trees, buy 2 telephone poles, a 10' section of telephone pole with the ends cut in a semi-circle(unless you want to go for some sort of joint which may be more secure), and get four 1" steel cable guy wires with anchors....
I would hang a 3" iron water pipe between the trees drop some ropes from it, and be done with it, but I'm a retired, no-longer-practicing engineer. |
We built tree forts by nailing scrap lumber between 3 trees(triangle floor).... no naysayers to say it wouldn't work.... as I recall lasted longer than we needed it.....SmileWavy Of course today we'd need permits and insurance. |
Find an old piece of railroad track and secure to the two trees. Of course that won't give you the safety factor you need so you should then just cut the trees down and replace them with steel poles and bolt the tie to that.
(PS I'm kidding) |
i am so glad i dont have kids.. or trees.
Now that I have a plan, the question becomes, do I put myself in harms way and climb a ladder, resting against a tree? Or do I pay someone?
A near or real disaster here puts in you firmly in family lore for a generation! The kids need to witness it though and it must be filmed and posted for it to live in PPOT infamy.
But will likely end up with chitty ESPN ("new" F1 stylze) coveragehttp://forums.pelicanparts.com/suppo...eys/hiding.gif |
http://forums.pelicanparts.com/uploa...1522360409.jpg |
https://www.piedmonttreeclimbing.org/p/tree-swing-installation.html |
criminy.
This is a porsche website, therefore I suggest the solution include 'guessing' at (and then frustratingly setting at a wrong position)- torsion bar spline height. http://forums.pelicanparts.com/uploa...1522369142.jpg |
Now, you're talking!! Best idea, EVAR!
And my stooopid 993, with its coil-over suspension!!! I'll to figure out a way to use the old crap I took off my car!
Please tell me it wasn’t your siblings and cousins who played “doctor”! :)
| All times are GMT -8. The time now is 05:08 AM. |
