Salt Lake City Connecting Flight
I'm trying to use all points for a trip from PHX to SLC and back, so must do a couple of different carriers. I don't know the SLC airport at all so I'm hoping you can help me with a judgement call.
Planning on flying in to SLC on Southwest. Planning on flying out of SLC for Jackson Hole on Delta. Landing scheduled for one hour prior to the Delta flight, which gives me about a half hour or so to deplane Southwest and make it to the Delta terminal(s). I see Delta uses three terminals and Southwest two.
Not knowing how big the airport is, does that give us enough time to get to one of the Delta terminals from the Southwest terminals?
Thanks!
Old 05-17-2018, 12:11 PM
Unregistered
sammyg2's Avatar
I flew into and out of the SLC airport in April, the airport was pretty convenient.
Delta is in terminal 2, basically in the middle. Southwest is in terminal one IIRC. You could walk from terminal one to terminal two in less than 15 minutes.
Old 05-17-2018, 12:24 PM
motion's Avatar
Yep. Easy peasy. You could make the sprint in about five minutes if you needed to.
Old 05-17-2018, 12:47 PM
Thanks guys!! Much appreciated!
Old 05-17-2018, 01:13 PM
LakeCleElum's Avatar
What I do if within 400 miles: Rent a car and drive the 280 miles to Jackson....Some very scenic routes to be seen......That's just me....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-17-2018, 06:51 PM
