-   -   Marine battery quick connect plugs (http://forums.pelicanparts.com/off-topic-discussions/996924-marine-battery-quick-connect-plugs.html)
flatbutt 05-18-2018 08:06 AM
I'm installing a trolling motor on my rowboat and want to also install some kind of connectors to the battery. I'll be keeping the battery in a protective case so want to add these leads.
I found these online but not sure how to install them. Any help please?
https://www.globalindustrial.com/p/material-handling/dock-truck/winches/warn-w-battery-quick-connects-pair?infoParam.campaignId=T9F&id=241838&gclid=EAIa IQobChMI04mYldCP2wIVy9rACh3ftAikEAEYASABEgI4O_D_Bw E
I think the cables get soldered into these plugs
http://forums.pelicanparts.com/uploa...1526659585.jpg
and somehow those plugs are secured inside the housing?
dad911 05-18-2018 08:34 AM
I've used them. Anderson Powerpole. SB connector.
Very expensive at your link. I've used SB50, (50 amp, good for 100 amps at short durations) https://powerwerx.com/anderson-power-powerpole-sb-connectors
You can also get them from andymark.com with wires attached.
Crimp connections**, then they push in and lock.
Available in multiple sizes/colors/amps
** I solder also, but if crimp is done with a real crimper, it's probably better Basically I use a HD Crimper, heat with a propane torch (soldering gun won't get it hot enough) and solder (it will wick in the connector)
If your near 287/78 area, I can help you out.
flatbutt 05-18-2018 08:46 AM
Thanks, I'm about 40 minutes North/West of that junction. I'm going to order now and then follow up. Thanks again!
dad911 05-18-2018 08:59 AM
PM me when you get them..... we'll get it done.
flatbutt 06-02-2018 08:58 AM
just got two of these from andymark.com and thinking I'm a dummy. How the heck do I connect these in between the battery and the motor lines? Looks like I need to cut the cables and attach those ends to the devices and use red to red or blue to blue for the circuit connection?
http://forums.pelicanparts.com/uploa...1527958733.jpg
dad911 06-02-2018 12:30 PM
I was thinking 2 of these: 4 Gauge Battery Cable (am-3777) or these: Battery Power Cable, custom length, up to 36" (am-0339)
Cut what you have and you will have two pairs.
I don't know what size wire you are splicing to, but something like this should work. https://www.homedepot.com/p/Blackburn-Dual-Rated-Splicer-Reducer-1-0-Stranded-to-14-AWG-with-Solid-Barrier-Wire-Stop-2-Pack-ASR1114-B2-10/100126602
They have various sizes for the correct wire. I believe they sell a splice kit rated for underground/burial/liquidtight, but I couldn't find it online.
