Igloo Ice Chest hinges (and i suppose the latch)
what POS!
my ice-chest rivals the best boxes in keeping thing cold. it is one of those ultra-max ones. i had it next to the best ice-chests made and it equaled every one of them. yeti, engle, grizzly, etc. what sucks; i bet i am on my sixth set of hinges. i noticed there are Stainless steel and some more robust plastic ones. i think the icechest is just to make money on hinges and latches..:) anyone try the retrofits? http://forums.pelicanparts.com/uploa...1528145438.png http://forums.pelicanparts.com/uploa...1528145438.jpg |
I need this! Where to find? Any solution for the latches?
Clearly what you really need is a $500 cooler.
I replaced the hinges and latch on my 15 year old cooler (same hinges as in the link above; I went with the stainless steel latch). I probably spent $20 and may have been able to find a replacement for $35.....still ahead of the game and kept some plastic out of the landfill.
Mike |
Like your thinking, Mike. Well done sir! Sent from my iPhone using Tapatalk |
Thanks!!!
My only concern would be the screws stripping out with the stainless. I have a big white igloo too that’s great for meat I’ve made dead hunting and consider the hinges the part that breaks so a non replaceable part doesn’t...
Might also consider leather.
All those big igloos have crap hinges. So frustrating. Sent from my iPhone using Tapatalk |
I have been carrying/abusing my Igloo Lunchmate every day to work for 20 years now with no problems. No hinges to speak of, but has performed flawlessly, and kept things cold in a warm environment.
My OEM hinges lasted a good five years. Got new OEM ones from my local Wally world for around $6.00. Ten minutes to replace and I was back in biness.
If you are worried about screw holes stripping out of the plastic I would suggest some epoxy on the screw threads . I would think if you are replacing the hinges and latch with decent quality stainless steel you are going to wear out the cooler before the metal hardware . So don't worry about having the ability to remove the screws in the future .
| All times are GMT -8. The time now is 01:16 PM. |
