Old VW engine question
My friend has an old Vw motor in his speedster replica. The alternator (or is it a generator) needs to be replaced. Is it as simple as pulling the alternator right out of the shroud or is the fan bigger than the hole meaning the shroud has to come off? Just curious before we start. Here is a picture. Thanks.
It will come right out.
Come right out. Did this proceedure on my 356C following the instructions in the best VW mechanic book ever - Muir's "Idiots guide to keeping your VW alive forever". Best $21 you or he can spend - https://www.amazon.com/Keep-Volkswagen-Alive-Step-Step/dp/1566913101
IIRC a 3 arm puller is needed (been 15 years since I did it) and you will need to confirm voltage coming out of voltage regulator and tweak if needed. (and for the purists who dropped their jaws when I said I used a VW book on a 356, I do use Elfrink's for the actual measurements - the Idiot's guide is rather well named for me, and it has wonderful "how to do it" directions. I just ignore the numbers and look up the right ones) |
That's a generator.
What is this in? The ease of removal will depend on whether you have enough room to get the fan around the generator stand. On a 356 it's apiece of cake because the generator stand unbolts and slides forward;I've considered mod'ing my VW engines similarly. You will need a 36mm socket and a way to hold the whole mess while you break the fan loose, and then again while installing it. |
Here's a pic (not mine). This is an alternator, but it shows the fan on the other end... http://www.vw-resource.com/images/020_painted_fan.jpg |
Here's my 356 engine with the generator out
http://forums.pelicanparts.com/uploa...1528319198.jpg http://forums.pelicanparts.com/uploa...1528319205.jpg |
It's in a Speedster Replica.
Will I need to remove the fan from the Generator (alternator) before I pull it out of the shroud. I just watched a video and that is what the guy did. Not sure I will get a hand back there to put a wrench on it. I hope not. |
I think the owner said it was a Miami based company that built the replica. That's all I know.
It looks like you might have enough room to lift the shroud and pull the generator (with fan still attached) straight out. Trying to get the 36mm nut off the back with the whole mess installed is a fools errand.
Good time to upgrade to an alternator. you will need the alternator stand to go with it because they are different.
Before you go to all the trouble of pulling the generator, first make sure that's the source of whatever problem is occurring and not the regulator.
Here's how to troubleshoot the VW's charging system: Fault Finding the VW Charging System Quote:
The generator shaft is wobbly. Making a lot of noise. You can wiggle and shake by hand. I mention all this to the owner and let him think what he wants to do.
Thanks everyone. |
From when I did mine, I recall there being 2 woodruff keys in there as well. When you order the replacement generator, just order some shims and woodruff keys - they are cheap and it is better to have them and not need them then need them and not have them. I didn't know there were 2 woodruff keys, so my car has just over half of a '65 nickel doing stellar duty as a shade tree fix (next to one correct woodruff key) |
check the brushes. they usually just wear out and can be replaced. not much else to really go bad on the gen,
| All times are GMT -8. The time now is 09:41 AM. |
