Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Targa_PB_78_SC
mike sampsel's Avatar
Door fit near front fender
Back in Ď84 we bought this 911 from the dealer in Dallas. Back when no requirements to divulge accidents.
Anyway the inside of the door was struck. It closes and works well and fits good except the door sticks out some as evidenced by the photo. So itís a cosmetic issue only.
However as a numbers matching 911SC Iím considering painting it.
Iím reluctant to go for the ďall outĒ paint job unless the door alignment can be made closer to original.
Anyone know if such a thing is possible/practical?
Maybe I go the less expensive paint route if door canít be fixed.
Old 08-02-2018, 05:03 PM
dkbautosports.com
962porsche's Avatar
it's common to have the leading edge of the doors on a 911 bend out when the door check breaks.
what happens then is the door stop when opening all the way on the inside of the very front part of the door and in no time at all the leading edge of the door starts to push it's self out.
it's easy to find out of the door is bowed out by laying a long straight edge across the door. if there is a space between the straight edge and the door it's a bowed door. they can be fixed.
the fender down the door gap in many cases can be moved out to make the panels match up.
some times you may have to long gate the holes a bit to get the fender to move out a little more .
in short what your looking at can be repaired and made to line up.
Old 08-03-2018, 05:50 AM
Targa_PB_78_SC
Wow thank you so much.
Old 08-03-2018, 06:16 PM
