Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
rokemester's Avatar
Mechanical prep for sympathetic respray
What can I do as a moderately skilled wrench to get an 87 Targa ready for a windows out repaint?
Old 11-04-2018, 04:39 AM
Roke, that's a wide-open question with many possible answers. I guess we could start like this:
- the quality of the repaint will be proportional to the amount/level of the prep work;
- the more a car is disassembled, the better chance for a job without nasty-looking masking and incomplete prep and paint application.
In my view, the 911 is readily disassembled but you need to be patient and organized. If you remove F&R bumpers, rocker cladding, lamps etc., you get a better job than simply leaving them in situ and having them masked.
Top level jobs (see the Blackhawk Rack thread, for example) take the car even further apart...fenders, lids, doors.
All depends on your expectations and budget. If you have a place to work on the car, basic tools, safe space to store the parts you removed and again once they come back from the paint shop (to reassemble), and are patient and quality-oriented, then you can add significant value and quality to your paint job. Look at how pro's work and see what you can emulate. Importantly, talk to shops who might do the paint and ask them the same questions.
I hope that helps.
John in CT.
Old 11-04-2018, 09:13 AM
rokemester's Avatar
Thank you, yes extremely helpful! Iím going to assume that most if not all of the body molding & seals will need to be replaced. I know the windshield and the rear Targa glass and cover need to be removed. Not sure about the door glass, but thinking wing window and door glass come out too. Iíll check out the other thread you mentioned.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 11-04-2018, 01:45 PM
Check out the projects done by this excellent shop in Ireland, Classic Carreras.
Classic Carreras
You'll get some good ideas as to how a good shop takes a 911 apart for body refinishing.
Old 11-04-2018, 02:06 PM
rokemester's Avatar
Excellent! I knew I would get some helpful advice here!
Northeast Ohio
1966 VW Beetle, 6V
Old 11-04-2018, 02:08 PM
rokemester's Avatar
Classic Carreras
Just checked out the shop in Ireland! WOW.
Old 11-04-2018, 02:35 PM
