Science is NOT optional
bumper cover, can this be saved?
the passenger side took a hit. can this be massaged back into shape?
the center fin is wavy. hopeless or what?
PCA member since 1993 |
dkbautosports.com
yes i have saved lots worse.
i bet. is it hard to get the shape to relax back into position or how is it done? consider that i have some enthusiasm for it but only to a point.
962, do you use heat to relax the plastic back into its original shape? Best, John
yes, does that work?
or do you need a form to reshape it?
dkbautosports.com
most of the time some simple heat and pressure to move it back into shape will work fine.
some times you will have to take a piece of wood and grind and or cut it to get a basic shape of what you need then heat the area and mold it again but for what i'm seeing on that bumper you shouldn't need to do it. |
