-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   graffiti on the window and paint. (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/1028736-graffiti-window-paint.html)
rbogh901 05-05-2019 09:59 AM
Bad luck, some lowlife went through the neighborhood and shot my car with an acrylic sealer. Could be worse I guess. At least it's clear and mostly on the glass. What are the best ways to proceed? Thanks all.
rbogh901 05-05-2019 10:06 AM
http://forums.pelicanparts.com/uploa...1557079405.jpg
rbogh901 05-05-2019 10:08 AM
http://forums.pelicanparts.com/uploa...1557079603.jpg
Vandalism actually, not graffiti per se.
rbogh901 05-05-2019 10:14 AM
http://forums.pelicanparts.com/uploa...1557079766.jpg
Found this in the vicinity. I imagine this is what they used.
speedster911 05-05-2019 02:04 PM
use a non acetone based fingernail polish remover - I have used the stuff whole foods sells but it's expensive.
jjeffries 05-05-2019 06:03 PM
Go ask a local bodyshop...will likely get it done in a few minutes. If not, you may get away with something as (relatively) gentle as mineral spirits; if not, a stronger solvent like PrepSol or 3M All Purpose / Wax Remover (auto parts store). Or, from the hardware store, Goof Off. Don't do any of this when the surfaces are hot and/or direct sunlight. Best of luck, John
DaddyGlenn 05-06-2019 06:38 PM
I feel your pain. This was my car a few weeks ago.
http://forums.pelicanparts.com/uploa...1557196508.jpg
Careful color sanding with 3000 grit followed by compound and polish. It took a few hours.
scottrx7tt 05-07-2019 03:51 PM
On the glass, just take a razor blade to it. The paint... a decent rubbing compound should take care of it without too much hassle
Cairo94507 05-08-2019 08:32 AM
I would start with a clay bar and detailing solution and see what that knocks off before you start using rubbing compound on the paint. Then I would go with a nice super high grit wet sand to remove what you can before polishing. Remember to tape off edges and be careful near them. On the glass a razor blade or 0000 steel wool with some detail spray will take it right off. There are sadly a lot of people in the world who have no regard for other people's property.
dustim04 05-13-2019 07:17 PM
You can also try using Goof Off.
rbogh901 05-15-2019 08:23 PM
Thanks all. I looked up acrylic removal and it suggested rubbing alcohol so I used a cotton t shirt and got most of it off. Still needs some help but it was pretty mild.
http://forums.pelicanparts.com/uploa...1557980579.jpg
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
