Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
ChrisBennet's Avatar
Adhesive instead of welding?
My brother-in law told me that today's adhesives can be used in some places that used to welded.
The kidney bowl on a 911; normally this requires removing part of the fender.
I was wondering if maybe I could avoid this by using adhesives instead of welding.
My car is a former race car and they cut a hole through the kidney bowl to run oil lines.
The car is a 1980 so it has the "small" kidney bowl. Later kidney bowl is bigger and I think it will fit *over* the old one.
I don't have time to weld it (going to die before next driving season, long story) but I thought this might be clever a alternative to welding.
Adhesive link:
Welding VS 3M Panel Bonding Adhesive
Here's some pictures of how is usually done.
http://www.classiccarreras.com/911carrera.html
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 09-09-2019, 07:14 AM
onboost's Avatar
Interesting question.. You are correct in that there are numerous adhesives are used in some places instead of welding.
I know we do this in some areas of repair, including structural, with Porsche and other cars but they may also typically be support by a weld somewhere.. and this is with aluminum. Not sure which adhesives are being used to bond steel in the manner you speak of.. although 3M is a good place to start.
RGruppe #180
Old 09-09-2019, 11:44 AM
The Mighty Pieholio
Bob Kontak's Avatar
I use a two part adhesive product called Plio-Grip. They have various adhesives. Maybe worth a look on-line.
If you find the right product it's important to put the squeeze on while the glue sets which is a "no-duh" statement.
I have used it primarily for pickup truck rear wheel arches. I cut the rust out and trim the remaining metal so that the repair panel can be crafted to fit. I use a pneumatic die tool that stamps a recess into the original opening lip and the repair piece fits relatively flush with the rest of the bed.
I use aluminum rivets to hold the panel in place while the adhesive sets up for a day. I just use 80 grit on a DA sander and knock the rivet heads off.
All of that said, wheel arch sheet metal is not a structural focal point.
I took pics with my IPhone. That's why they are sideways.
1981 911SC Targa
Old 09-11-2019, 01:17 PM
Cairo94507's Avatar
ChrisBennet - I hope you were kidding about dying before next race season.....
2016 Audi S3 DD
Old 09-12-2019, 10:48 AM
pete3799's Avatar
Yeah.......me too.
Pete
79 911SC RoW
Old 09-12-2019, 06:52 PM
Awesome guys.
Sounds like the aluminum rivets are the way to keep it "squeezed".
(Yes, brain tumor. Hoping get my strength back enough to drive. I am happy though, so don't feel bad for me. Today I found out my time horizon may be a little longer, probably not for driving though.)
'07 BMW 328i Coupe
Old 09-13-2019, 05:24 PM
pete3799's Avatar
Wishing you the best Chris. Hang in there.
Pete
79 911SC RoW
Old 09-13-2019, 09:55 PM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Or small sheet metals screws which negate the need to grind, especially in tight areas.
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
Old 09-14-2019, 11:52 AM
The Mighty Pieholio
Bob Kontak's Avatar
Yep. Body welding vice grips/c-clamps too, where possible.
All the best to you, Chris.
1981 911SC Targa
Old 09-15-2019, 08:56 AM
Cairo94507's Avatar
Wishing you the best and hope you get to drive that baby.
2016 Audi S3 DD
Old 09-16-2019, 10:14 AM
