Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Panel Adhesive
Hi all,
I need to attach on a couple of metal tabs to hold on the fuel vapor tank under the fender of a 1970 911. I was hoping to find an adhesive that could do the job rather than welding because I cannot access the area. I know 3m makes a panel bond epoxy (say #38315) but all of their adhesives require a gun/applicator. Is there anything out there that would do the same thing that I can mix and apply by hand?
Chris
Old 10-07-2019, 10:05 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Chris - maybe something like this will work.
Attaching the general link for the adhesive section here.
Hope this helps you out a bit.
Old 10-07-2019, 02:38 PM
Originally Posted by chris belyea View Post
Hi all,
Chris
Panel adhesive is probably not the best option, remove fender and weld it or possibly lose it going down the road which will cost you more time and money.
Old 10-09-2019, 06:38 AM
Try also to go to a local bodywork supply and ask for recommendations.
Old 10-16-2019, 07:37 PM
