Another Air System Question
So, I did a search and didn’t find exactly what I’m looking for.
I have a 60 gallon/155 psi air compressor located in a closet I built adjacent to my garage. As a part of the design, I fabricated a wall mounted air condenser to hopefully capture a great deal of moisture before the air enters into the garage. Once inside, I plan on installing a simple filter dryer assembly to capture to remaining gross moisture in the system before the air travels to typical service connections for my lift, hose reel and a few tool connections. I intend to T off the outlet of the filter dryer assembly with an isolation to a desiccant filter which will be a dedicated paint sprayer connection for painting and powder coating purposes. I have the desiccant filter in hand - looking for recommendations for the initial filter/dryer. I’ve looked at a few - but find value in the collective brain trust here. Thanks for reading and sharing your experience/recommendations. |
| All times are GMT -8. The time now is 07:13 PM. |
