measuring fender flares
Is there a way to measure fender flares to see if they are symmetric to each side?
There was a thread years back about setting up stamped turbo flares. I found it easy to use a known origin that should be the same side to side ... the jack tube on the rocker works perfectly. Just make sure before you start to measure and make sure that someone didnt do half ass repair job and move it in the process.
welding flares, longhood RSR, alignment questions. |
Can't you just measure the inside of the wheel well. In other words, hoist the car up so the wheels drop a bit then measure from the inside to the fender flare.
I'm not sure.... I'm sure there's a specific way to measure it. Just trying to figure it out.
