-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Help with Solvent Pop (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/1126109-help-solvent-pop.html)
thetorch 09-09-2022 02:33 PM
Super frustrated trying to paint a few small items like my fog light covers on the lower front bumper. If I get it wet enough, getting what looks like solvent pop immediately. Happens on first coat over primer. No fan, no heat being used.
I have tried pressures from 15 PSI to 40, different volumes, different coats from barely covering to full wet. Higher pressures seem to have fewer pops but create horrible orange peel. Lower pressures (15-20) should be correct according to Iwata. Small gun so shooting 4-6 inches away per spec.
Paint: Axalta Nason Spectramaster Ful Thane (Dupont) single stage low VOC 2.8
Activator: Axalta Nason 483-30 Ful-Base Activator
Reducer: I have tried both Nason Med Temp and High temp (slow) Reducer
Suggested mix: 4:1:2. I have tried 4:1:1 and got less pops but worse peel. I have not tried 4:1:1 with the slow reducer yet.
Paint temps: shot between 78F and 82F, inside and outside. No difference.
Gun: Iwata LPH80 with 1.2mm tip. I have also tried a 0.8mm tip.
Helpful suggestions welcome. My instinct is that it's related to the gun setup: shooting too close is causing the paint to skin and pop?
http://forums.pelicanparts.com/uploa...1662759045.jpg
Bill Douglas 09-10-2022 09:09 PM
That was bad luck Torch. If no one chimes in maybe post the same question and pic on https://www.autobody101.com/forums/viewforum.php?f=5
Umm, sounds like you know more than me on the subject, but all I can add is are you sure it's solvent pop and not some moisture (water) coming through.
I had a similar looking problem and our man Dpmulvan put me onto descant filters and it fixed it.
thetorch 09-11-2022 06:09 AM
Bill,
Thanks. I Have 3 filter/driers in the lines, including one at the gun, have very carefully degreased/dewaxed and dried the pieces, so I don't think it's water or contaminants.
Your point makes me think of something I hadn't before.
Shop humidity was 18% during at least one day I painted. Maybe it's drying too fast, skinning over before the solvent can evaporate...daytime humidity looks like it was between 11 and 50% the past week... Something to think about anyway.
Thanks for the suggestion. I consulted a good friend and painter. He believes it the paint. Going to try another batch / brand this week, and pay more attention to the air humidity...
-Torch
Dpmulvan 09-11-2022 07:02 AM
I just painted this yesterday almost same color as yours,http://forums.pelicanparts.com/uploa...1662904862.jpg
Dpmulvan 09-11-2022 07:07 AM
What’s underneath did you use a wet on wet sealer? 1.2 tip is a little small.
Dpmulvan 09-11-2022 07:15 AM
Orange peel is too much product and not enough air atomization. Get the tds for your paint and follow it. Pressure going into the gun should be between 25 ish depending on gun. Try using a 1.3 or 1.4 tip. Also when did you prime, did you use a sealer and if so what type. Your solvent pop could be coming from the sealer or primer underneath. If no luck let it dry sand with 1500 then 2000 and see if you can get rid of nubs. Sometimes you’ll get lucky and be able to sand them and buff them out.
Dpmulvan 09-11-2022 07:29 AM
<iframe width="560" height="315" src="https://www.youtube.com/embed/R5X_9RTMR6Q" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Dpmulvan 09-11-2022 07:34 AM
https://youtu.be/R5X_9RTMR6Q
thetorch 09-11-2022 07:43 AM
I tested on epoxy primer, 2 part high build primer sealer (both flashed and also some that dried for a week) sanded and cleaned, on top of 1 and 2 coats of fully cured (a week) then 600 grit sanded basecoat, and even scuffed and super clean bare metal just to see if it could be the underlying surface.
Mini bubbles appeared on every single test panel in the same way.
I tried every 5 PSI from 15 to 40.
It's possible it's the gun. However, I followed the spec sheet for the paint to a T. A 1.2 tip should be just fine and in fact is recommended (1.2-1.4mm). Truly you can shoot small stuff with 1.2 and I have even done 0.8mm with proper adjustment to volume and pattern and distance.
If it's the gun or my lines or my technique, another brand/batch of paint will not fix it and I will eliminate from there. That's my next approach.
thetorch 09-11-2022 07:46 AM
Looking good!
Dpmulvan 09-11-2022 11:03 AM
Hopefully 962 will chime in, he’s got a lot more experience than I do and I learned a lot from him over the past 5 years.
thetorch 09-11-2022 02:38 PM
update
Well, I decided no harm in trying to cut and buff the fog light hole covers before repainting them.
The little bubbles pretty much buffed right out with some 1000,1500, then cut and polish.
Not sure I want to do that on my engine panel with all the recesses, which is what started this whole project in the first place. gonna think about that...
http://forums.pelicanparts.com/uploa...1662932087.jpg
http://forums.pelicanparts.com/uploa...1662932292.jpg
Dpmulvan 09-12-2022 07:44 AM
Some water traps are useless, what kind are you running? Compressing air causes heat the air needs to be cooled down before you can extract the water. A water trap connected directly to the output of an air compressor is essentially useless. I don’t paint enough to justify buying an air dryer but you can make one out of copper pipe. You run the air out of the compressor through about 20 ft of copper pipe then back to the compressor tank. Several ball valves at the bottom of the copper loops are opened to drain out water. Just a thought in case your still having issues
thetorch 09-12-2022 06:45 PM
update: Went to get a color match done using PPG Delfleet Essentials single stage. No pops right from the get-go with my test panels. Color match looks stellar: better than the ones I got from Sherwin Williams 2 stage and the Dupont Nason single stage.
3 coats done. Laid on much easier and better coverage -- there are a lot of solids in the Delfleet.
Fellow customer at the paint store said a bad batch of activator caused similar popping for him doing a Mustang with Nason ful thane. Maybe that was my problem. Not sure.
Very happy with the Delfleet.
http://forums.pelicanparts.com/uploa...1663033355.jpg
Bill Douglas 09-12-2022 07:08 PM
well done.
Love the color too.
Dpmulvan 09-13-2022 07:33 AM
Glad you got it sorted, looking really good is that ossi blue??
thetorch 09-13-2022 07:54 AM
Yes, the one and only Ossi Blue.
jjeffries 09-13-2022 12:49 PM
That’s pretty. For the lines which count, are you using proper (green 3M) making tape?
John
thetorch 09-13-2022 12:57 PM
It's all soft edges so I didn't use green.
962porsche 09-14-2022 08:44 AM
like Dpmulvan stated looks like water in your air supply system.
being you said you buffed them out my guess too is water in your air system. if it was solvent popping then they would be much deeper than just on the top surface.
solvent popping is caused by a few things but the main one is to much material is sprayed at one time with out letting the coats under it flash off long enough. so the top coats you sprayed dry faster than the 1st coats . with the solvents having no wet surface to escape thru and with the top layer/s more dry the solvents push thru the top layers and leave pops in them.
also with spraying to much to fast to soon you can get delimitation problems. this is because the top coat/s have dried well before the 1st coats and the solvents can't escape at all so they travel along under the more dry top coat/s and delaminate the top last coats of material. this you will not tend to see until months or even years later after the car is all finished.
to avoid water the best thing is to get a dryer system. there are a few different ways to dry the air.
there are systems that will cool the air coming out of the compressor but they are costly.
another lower cost way is to install a desiccant dryer. they remove the moisture from the air with beads.
the loop systems will work ok but there are times if your compressor is running hard that you could find some air still getting to the end of your air line.
dry air is a big help not just because it can ruin your paint work when your spraying but it could also be spraying contaminants all over when your doing body work.
a good dryer system will also help in prolonging the life of your tools also.
that moisture your getting at the end of your air hose is also going thru your air tools rusting the crap out of the insides of them.
a desiccant system will run from 150 to 700$ depending on how crazy you want to go.
the time it takes to repaint and the cost of having to buy more materials in most cases will cost you much more than a few hundred bucks to just buy a good dryer.
thetorch 09-14-2022 09:37 AM
Thanks for the thoughtful response. The pops occurred on the first coat, so it wasn't related to second coats or flash time.
I have a desiccant system and an inline water and oil Separator at the gun. Maybe I need to upgrade my drier to a higher quality one.
Bill Douglas 09-14-2022 02:24 PM
I'm pleased to help. I thought the pic's looked like the water issue I had, and the desiccant dryer sure fixed it. My desiccant dryer isn't a terribly fancy or expensive one. It sits on the compressor side of things, just after the ordinary water trap type one that came with the compressor.
I do take the beads (crystals) out and dry them with a hot air gun each time I'm going to use the sprayer. Mine go from blue to pink if they have moisture in them. A minute or two of hot air while being swirled around in a stainless steel bowl works for mine.
962porsche 09-15-2022 04:32 AM
if you are getting water and you do have a desiccant dryer it could be from a number of reasons.
like Bill stated you can dry most beads a few times before they will still need to be replaced.
if your compressor is on the smaller side and has to work hard to keep up with a high demand of air uses then at times you would need to go with a bigger dryer.
things to do even when your using a dryer is to make sure it's mounted as far away from the air supply as it can be.
make sure its mounted higher than the air compressor so moisture will be able to drain back to the compressor .
still putting a few loops up and down from the floor to celling before the dryer is a good idea like stated before in the posting replies. with bleeders at the bottom of the loops. this will let you drain any moisture from the air supply line.
another help is to crack open the drain valve just to let a very small amount of air and moisture to bleed out before it gets to your dryer.
thetorch 09-26-2022 05:47 PM
Well, I learned a lot on this project. I think the Nason paint was bad, not that there was any water in the lines. I think the gun + the DuPont Nason was a bad combination for some reason.
My previous post had a decent amount of orange peel, and I burned through one edge while polishing it. I had laid the paint just too thin on one area.
So I sanded it down and took another shot at it. Laid down so flat that I didn't need to color sand at all. Just a little blend and polish and done.
Finished product:
http://forums.pelicanparts.com/uploa...1664239604.jpg
Bill Douglas 09-26-2022 08:49 PM
Congratulations. It looks spectacular.
Monkey Wrench 09-28-2022 11:59 AM
any piston compressor will also put oil in the air. the desiccant filter can have some water filter bowls prior to, then they catch a lot first and you can watch them to see if water is collecting. some have a ball that floats and then it opens the bottom pushing some air out with the water until the ball stops floating then it seals. the desiccant will last longer if it has less water to catch.
you can chill the line, or add a second tank. If its a long line you may find even after you filtered it more can come out. a cheap thing you can do is plumb in a foot or two of drop in metal pipe , the water wants to settle in the pipe and you can add a tap on the bottom to open, It acts as a sediment bowl basically but you can just make that from pipe and fittings.
some add oilers to oil their air tools, don't use those air lines for painting, they are contaminated. If you dont have an oiler or want oily air lines, you can put oil in any air tools that require it when you connect it to the line.
drain your compressor often enough , more when it's humid. you can add an autodrain for about 200 bucks, then it blows off the bottom of the tank for 5 seconds or so on a schedule set by it's timer.
if you dig into it there are ISO standards for air, you can consult a pro and they will help you size and choose your filters or dryers etc to meet the standard. different machines, hospitals etc may comply to set standards for oil or water contamination. in some cases the air quality can affect warranty coverage for certain machinery and the user may be responsible to maintain it because the water can cause a lot of damage to pneumatic systems etc. the bowls dryer etc should really be matched for particulate size , water but also be right for the CFM of the application. Shoes that are too big won't help them work better. If shopping you want the CFM , compressor type, length of run, the quality desired etc, from that, any decent company that supplies comressrs will have techs that can help you make good choices.
the filters and the bowls are nto all made the same there is a big range in quality, some are units with 3 or so bowls in one unit they can also be plumbed separately in a daisy chain. If they are a unit then you need to be able to get the filters and parts from the vendor. If you separate them you can have 3 different brands of filter bowls. Id recommend to try to get parts that are common because you can end up needing to replace it if you cant get the filters easily or if they are super expensive. Ingersoll Rand is a good brand, not the cheapest, but there are many others.
I'd keep some spare filters, If you see them get soaked, throw them away and drain your compressor more. some people try to cheap out and dry the filters. false economy if that causes trouble. If you by a filter bowl arrangement try to get a common brand so the filter availability isn't going to stop what you need to do. dryers work by refrigerating the air, some need them , some don't.
I look upon air lines as tanks as well, they act as tanks, they hold air so if you have a lot of hose that's a vessel, it's just a long skinny one. as the air goes through the hose and sees cooling and maybe goes over a rise or a fall then you can find more water coming out from your air along the way, so you can add filters near the compressor but also at the user end.
I dont know as much about pro painting as you guys but the air quality can be made to meet certain standards. Hospital air is one of the higher ratings for example. you cant be feeding people air from a piston compressor as they would then be exposed to the oil , the oil is caused by blow by from the crankcase of the piston compressor past the pistons rings.. some who use lots of air have screw compressors and they work differently. the loud as hell pancake compressors don't have the oil output issue as its a vibrating rubber diaphragm not a piston so the air is separated from the oil for the crank by the diaphragm, and it won't have pistons.
All I can say about the paint work is I just love that brilliant shade of blue !
