-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   911SC Front Valence Conversion (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/1140205-911sc-front-valence-conversion.html)
JB630 05-18-2023 11:20 AM
Does anyone have experience updating the front valence on a 911SC to the 3.2 Carrera style with the fog light holes? If you used aftermarket parts, do you have recommendations on where to purchase and if it was bolt on or required fabrication? Were you able to reuse the existing fog lights or did you need to update them? Apologies if this isn't the appropriate forum.
onboost 07-13-2023 05:15 AM
The 3.2 Carrera valance is interchangeable, you will also need to use the 3.2 style fog lights.
Aftermarket parts (assume you mean fiberglass) will be a toss-up, some fit better than others.. if you're looking for metal, I would try Restoration Design as they make very good replacement sheetmetal for Porsche.
Lastly, it may be fairly easy enough to find these parts used.. local shop, ebay, or pelican.
Bsess 07-15-2023 05:19 PM
Having done this multiple times, the existing fog lights can be used but you will need the updated Carrera fog light housings. You will also need to switch to the later style washer fluid tank (smaller in size) that sits behind the left fog light.
Chino 08-23-2023 05:23 PM
I have these available, used aftermarket and another twin slot (not pictured), all need body work. Local pickup in Sacramento CA. Link to my old posting.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1051322-911-front-spoiler.html
