Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Wrighteous's Avatar
Rocker trim on flachbau
Hello there,
I removed my sideskirts for a suspension refresh and both external and interior rubber trims needs replacing on one side. Does anyone know a PN or have any ID on these pieces?
Many thanks!
Old 06-21-2023, 07:28 AM
Wrighteous's Avatar
Old 06-21-2023, 07:29 AM
Wrighteous's Avatar
Having trouble uploading an image, but there is a smooth rubber outer trim on the box rocker. Between that rocker and body there is a moulding that has serrations to it (to accomodate for curves presumably). Rocker trim on flachbau
Old 06-21-2023, 07:30 AM
onboost's Avatar
The inner rocker trim should be sold by length, it is the dame trim found around the base of the whale tail where it mounts to the lid. The outer rocker trim is just that, just G-body rocker trim.
RGruppe #180
Old 07-13-2023, 04:03 AM
onboost's Avatar
RGruppe #180
Wrighteous's Avatar
Thank you onboost, that's a great leads! I'll measure off the piece I have and buy some tonight.
Old 07-13-2023, 02:05 PM
Tags
flachbau , rocker , slantnose
