Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
need info on fender rehab
rear aluminum bumper had corrosion.
Has been sanded and ground out.
Do I use or should i use Epoxy then Bondo?… then acid etching primer then paint?
Or is there a better procedure or products?
Old 04-03-2025, 01:18 PM
You don’t need acid etch primer, it’s for bare steel generally.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 05-24-2025, 03:57 AM
dkbautosports.com
962porsche's Avatar
you epoxy primer then use a quality body filler ( not a fan of bond brand filler ) then epoxy primer , prep and top coat.
Old 05-31-2025, 01:14 PM
Tags
bondo , bumper repair , paint
