need info on fender rehab
rear aluminum bumper had corrosion.
Has been sanded and ground out. Do I use or should i use Epoxy then Bondo?… then acid etching primer then paint? Or is there a better procedure or products? |
You don’t need acid etch primer, it’s for bare steel generally.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
dkbautosports.com
you epoxy primer then use a quality body filler ( not a fan of bond brand filler ) then epoxy primer , prep and top coat.
Tags |
bondo , bumper repair , paint |
