Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
1987Driver's Avatar
White Wax Removal From Rubber
Whats the best cleaner to use to remove wax from the stone guards and other bits of rubber/black plastic?
1987 911 Convertible
2006 VW Beetle Convertible
2003 Dodge 1500
1966 Impalla SS Conv. (departed)
Old 12-10-2006, 06:20 PM
zero9nine's Avatar
I am trying to find a solution for was residue removal as well.
I just purchased a very nice RS America. Previous owner waxed it often but their is residue in every little crack and crevice.
What is the best way to remove the residue? Is their a solution that will break it down?
John
John
www.P1-MotorSports.com
Old 09-03-2010, 04:14 PM
zero9nine's Avatar
Founds this online:
Tires Exterior Rubber and Vinyl Protection
John
Old 09-03-2010, 04:24 PM
zero9nine's Avatar
I spent the day with a bottle of cirtus degeaser and some rags. :-)
It worked very well. Still need to go back and touch up some spots. The wax residue was heavy on this car.
One suggestion. Pour some citrus degreaser into a smaller container because if you keep dipping your brush into it it will become dirty.
Have fun!
John
Old 09-04-2010, 05:51 PM
Tug68's Avatar
Mothers Back To Black works well also...
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 09-06-2010, 04:51 PM
Brillo's Avatar
Originally Posted by tug68 View Post
mothers back to black works well also...
+1
Ray H.
1979 911SC Coupe
2000 986
Old 09-10-2010, 08:47 PM
17 years and 17k posts...
azasadny's Avatar
I use Griot's "Dried On Wax Remover" and it works very well. Give it a minute or 2 to work before wiping it off...
Art Zasadny
2010 MazdaSpeed3 (Sold)
www.ford.com
Old 09-19-2010, 07:23 AM
Charles Goodyear is also responsible for the Blimp that flies over football stadiums. There were originally two types of lighter than air craft. The A - type was rigid and the B - type was limp (combine B - limp and you have Blimp. Cool!). Expect un-vulcanized rubber to be a mix of very long limp chain molecules like a bowl of spaghetti. That makes them rather flexible until stretched taut like a rubber band taking out all the slack. Vulcanized rubber added sulfur to the mix to help take out the slack. Rubber bands can be manufactured by dipping a rod of the correct diameter into a batch of (latex) rubber and letting it cure. The rubber bands can then be cut from the rod like so many O'rings (side by side). Early un-vulcanized tires often punctured (even several time during a long trip). Some gave up and stuffed them with grass, etc. just to get back home. I don't believe that Goodyear invented the blimp but they did use it effectively for their advertising.
Old 09-20-2010, 11:15 PM
Laneco's Avatar
That is very cool!
Not sure what it has to do with removing wax, but very cool nonethless.
angela
1970 911T - Steve's car NOT Angela's...
550-A6 spyder -SS 3.2
81 Coupe "Butters" SCWDP #0036
Dad's SS - 87 Monte Carlo Aerocoupe
Traveling sucks, but it sucks a great deal less when you're driving a Porsche.
Old 10-18-2010, 08:24 PM
gilbert8tr's Avatar
I think microfiber mitts/towels and wool mitts are both good options.You should ALWAYS pre-rinse the car with high water pressure (as high as you can) to blast off the bigger stuff first.
Old 11-16-2010, 02:49 AM
Alps Adventurer
Traveller's Avatar
Send a message via Skype™ to Traveller
I use a soft fine bristle tooth brush and lightly oscillate it over the surface using my water-based degreaser soap.
Next time, use less wax and use it where it belongs.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 11-23-2010, 06:05 PM
