Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Warren Hall Student
Bobboloo's Avatar
Paint prep advice needed
Need a bit of advice from the gurus here.
I've been prepping my car for the paint booth. In a couple places I sanded through my high build urethane primer exposing a little metal or filler.
What would be the best approach to deal with these spots? Can I just hit them with sealer before I color coat or should I seal them, let them dry, and then wet sand again before color coat?
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 01-13-2008, 12:30 PM
Bobby: if you are using a good sealer that should be enough, but double check on the areas where the filler is exposed, sometimes it also exposes pinholes,or just mix enough primer with a little bit of reducer and lightly cover them.
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT"
http://axiom-motorsports.com/
Rudy Ruano, Operations Manager.
Joseph Toliva, guy who signs my check
Old 01-13-2008, 01:59 PM
Warren Hall Student
Bobboloo's Avatar
Thanks Rudy. That's kind of what I thought. I just wanted to check with one of you guys.
Bobby
Old 01-13-2008, 02:13 PM
