Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
gestalt1's Avatar
patching ideas
hi all, my 68 912 has rusty floors and front pan half - these areas seem straightforward to fix. however there are a few areas that I'm not sure how to fix. the battery location area has rust along the bottom front of the inner fender panel. i have not seen a patch panel for this so do i have to fabricate this section? the drivers door by the hinges is dented (no idea how this could happen since the hinge post is fine). has anyone tried to fix this or should i just replace the door?
another thing i noticed is that the rear quarters are a little mis-matched. the wheel opening has no flare at all on the passenger side but the drivers side has a slight flare. there is no signs of panel replacement/bondo or rust so I'm wondering if this is normal. i plan on learning to hammer/dolly to make 911r flares so it does not matter but I'm curious about this.
thanks!
Old 12-22-2007, 10:20 AM
robmog's Avatar
front pan and battery support can be replaced with new sheet metal.
it looks like it was already done in the past. the battery support is a later model style. the inner fender repairs must be fabricated or sourced from a donor. i believe the non flared rear quarter is correct for 68 the flare is probably replacement, damaged to drivers door suggest collision on that side.
you can check by the B post to confirm relacment fender
bob
Old 12-23-2007, 07:43 AM
