-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Can i shoot epoxy primer with a 33gal compressor and cheapie gun? (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/382380-can-i-shoot-epoxy-primer-33gal-compressor-cheapie-gun.html)
berettafan 12-14-2007 06:00 AM
Reading the por-15 thread got me thinking i might like to use an epoxy primer on the interior portion of my front pan repair instead of POR (which i am using on the outside and have already used in the battery boxes).
I have a 33gal. air compressor and have seen paint guns for $30 at harbor freight. will i get a nicer finish (and better rust protection) by using such a setup to spray an epoxy primer? If I could do this cheap enough i kinda like the idea of doing the entire trunk in a battleship grey color; or maybe just spray black over the primer....
thoughts on this?
haycait911 12-14-2007 10:54 PM
no problem with that set-up. I use PPG DPLF epoxy mixed for slow cure. has a week pot life and sticks like crazy.
VINMAN 12-19-2007 04:18 AM
I use a cheapo Cambell Hausfeild gun for my primer work. Primers (especially epoxies)also need a bigger orifice and needle than topcoat paint. I save my good Devillbiss guns for my topcoats
rw7810 01-02-2008 09:46 AM
Actually I just used my Devilbiss 670 Plus gun with a 1.3 or 1.4 tip to spray PPG epoxy and it went down real smooth and easy. I cleaned it very well afterwords and I see no problem. See my thread above for pics. That gun rocks!
chris911sc 01-14-2008 05:14 PM
Keep in mind, its not the size of the storage tank the compressor has, its the CFM it puts out. To be on the safe side, you need a compressor that puts out around 10CFM at 75 psi minimal to spray a sizeable area (whole side of car or more). Since you are spraying a small area, a small compressor will work fine.
berettafan 01-15-2008 06:38 AM
thanks guys. after seeing DRM05's application in his trunk with a schutz gun and Wurth SKS (guessing it's SKS, not confirmed yet) I am thinking i'll go that route.
jess p 01-31-2008 09:07 AM
paint
Harbor freight sells awesome hvlp guns for $19. Use it and throw away. Dont
ruin a good gun.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
