Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Best technique / tools for sanding new widebody flares on an early car.
Hi all,
This is how my car sits currently:
One of my next projects is to finish the filler work on the flares.
What I'm hoping for are some tips and techniques for getting the right contour on the flare. I've heard that some people use rolled up magazines for sanding blocks.
Anyone care to share the whole process?
Thanks!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 03-19-2008, 09:47 PM
flatsixcrazy's Avatar
Hi, I used a short section of a 3-diameter PVC pipe. Andy
Old 03-20-2008, 12:52 PM
3.2 CAB's Avatar
You will find that you will be using many different items for the backing piece when sanding on those flairs and other areas also. You can, and may have to be very creative on your "block" material. It may range from a tongue depressor up to sections of 6" pvc pipe. You will find this out along the way. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-21-2008, 12:32 AM
