Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
gulf911's Avatar
How to strip fiberglass bumprers
Hello,
would like to strip and repaint my RS bumpers and need some tips on how to strip them first? I am not sure if sanding would work as well because there are portions of white fiberglass showing. Thanks in advance.
Dan
Old 02-26-2008, 04:33 PM
Soda blasting is in fashion nowadays, but you can use sandpaper, it takes a little more time, but it will save you money.
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT"
http://axiom-motorsports.com/
Rudy Ruano, Operations Manager.
Joseph Toliva, guy who signs my check
Old 02-27-2008, 06:44 AM
there is a chemical paint stripper made just for fiberglass. i think its made by clean strip.
Old 02-27-2008, 07:41 AM
gulf911's Avatar
Thanks for your responses! If I sand, can I use a hand sander like the "mouse"? Or similar? If so what is the device of choice for this? Once its sanded I have seen on the forum posts regarding the primer etc. to use. After the primer, could you use a product like paintscratch's can spray to spray the color? Do most then use a clear over the paint? This is a car that see's a fair amount of track time so I would like to be able to touch it up from time to time.
Thank you for your help!
Dan
Old 02-27-2008, 02:53 PM
If you want it to come out good, block the bumper with 80/120 grit(depends on how much paint is on it) Then shoot it with Euro or PCL primer. Then block it again with 360/400.
Old 02-27-2008, 04:27 PM
