Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Fender replacement....
So I removed my fenders on my 75 911s, was cleaning up some minor rust.
Question is what do I put between the fenders and the body before re-assembly....i removed a silly puddy like substance during removal.
Any tips for getting it to all line up again?
Old 02-28-2008, 04:03 AM
abit off center
cgarr's Avatar
You can buy the ribbon tape that goes there, or make a rope of plumbers putty, that works too.
______________________
Craig
G2Performance
Old 02-28-2008, 07:05 AM
Ribbon tape...can you provide more info or a link?
Old 02-28-2008, 05:46 PM
abit off center
cgarr's Avatar
Give PP a call, I cant find it in their catalog but I think they carry it, its like a sticky putty tape and it comes in a 5 meter roll.
Craig
G2Performance
Old 02-28-2008, 06:23 PM
moliver,
I've read posts of people using a 3m product. I think this is it:
http://autobodystore.net/Merchant2/merchant.mvc?Screen=PROD&Product_Code=3M8578&Categ ory_Code=JASS
I tried doing a search but couldn't find the right thread. I remember it being buried pages down on an RSR conversion post.
Hope this helps, maybe someone esle with more knowledge will chime in.
Matt
Old 02-28-2008, 06:54 PM
Thanks for the link, I was looking for something similar but couldn't find it.
Old 03-01-2008, 03:42 AM
3.2 CAB's Avatar
Porsche Crest Thread about fender tape.
I believe this is the one you were looking for.
Rosewood gets a paint job.....
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-01-2008, 06:30 AM
So, has anyone put a fender on dry?
I Por15ed both mating surfaces...and tossed the fender on and don't really want to take it off to goop it up and reinstall it.
Not being lazy but maybe a bit...does the goop trap moisture? Where going on dry might keep things a little dryer?
Just looking for some comments and experiences.
Car is going to be a nice weather weekend drive...and maybe some track.
Old 03-13-2008, 04:15 PM
I don't see a problem with putting them on as long as both mating surfaces are protected. IMO, Vw/Audi/Porsche used way to much seam sealer on the fender mating surfaces. An alternative could be to use some good quality undercoating or use the Wurth sprayable seam sealer. Both can be applied after the fender is installed. I prefer the Wurth seam sealer because it can reproduce the factory look inside the fender/cowl joint.
Old 03-13-2008, 05:47 PM
