Ax and Buck,
Thanks for the replies. Regarding the reduction: 8 paint : 2 reducer == 4 paint : 1 reducer. The "1" part of 8:2:1 is the hardener. Per your suggestion, I would only be doubling the hardener and I'm not sure that was your intention. If so, that's what I'll do. The gun being used was brand new (different from the 1.8 gun used for primer described earlier in the thread) and I mean brand new. The finish coat was the first time used. I simply ran a few squirts of reducer through the gun before painting. Regarding the needle setting, Unfortunately I'm not sure what you are saying. I did turn down the fluid control a bit to help control the runs I experienced earlier. How do I adjust the needle setting? This gun (Advanced Tool Design Model 6900) has three adjustments: 1) spray pattern knob on side of gun 2) Fluid adjustment - big knob at back of gun 3) Air Adjustment small knob at bottom of handle next to where the air inlet is. I've adjusted the pattern and fluid to try and get a wet edge while minimizing runs. You can see some test patterns in the background of the picture of the hood posted earlier. I did turn in the fluid control to help minimize runs. Again, than ks for the replies. From compiling the replies it seems I should: 1) reduce the paint an extra 5% 2) reduce the pressure a little 3) Double the hardener (hopefully Ax will clarify first) 4) open up the fluid needle, I'm assuming by using the fluid control Any further help would be appreciated, thanks again for the suggestions. jmd_forest |
Do a test panel first, with very little mixed paint using the ratio I gave you, with regards to the fluid needle, adjust as follow, with empty gun, unscrew the big know almost all the way out, then press the trigger and start screwing the know in, when you feel some resistant at the trigger, stop and lock it, if lock is provided, that is open all the way.
On your test panel, do a medium pass first, follow by a wet one, and see how your paint flows. |
DON'T double the hardener!! won't do any good for this problem and will, down the road, cause issues. Ax will confirm this. I also wouldn't reduce the pressure at this point. Just start by reducing the paint that 5% and see what that does. You'd be defeating the purpose by lowering the air pressure with reducing the paint.
A quick painting 101... Problem; Dry spray Solution; Heavier coats, turn down the air pressure, move gun closer to the work, don't thin paint out to much, turn up fluid flow, use slower reducing solvent. Problem; Orange Peel Solution; Lighter coats,turn up the air pressure, reduce the viscosity, back off from work, turn down the fluid pressure. Problem; Sags/Runs Solution; Lighter coats, faster reducing solvent, move gun distance back from work, turn down fluid flow, turn up air pressure. These are not all inclusive but they are a starting point. Have you used this brand of paint before? You've had 'great' results in the past. Wondering if the paint isn't the issue. |
Correct again Mark, doubling the hardener on a acrylic enamel is not a good idea.
8 to 2 is the same as 4 to 1. Follow Mark's guidelines, they will get you there. |
Thanks for the tips. I have never used this brand of paint before. I couldn't get acrylic enamel at either of the local auto body shops, and since I didn't want to chance crazing/lifting the existing acrylic enamel paint, I found this stuff on the internet from TCPGlobal/Restoration Shop. Paint I've used previously: Dupont Centuri Acrylic Enamel, Dupont Acrylic Laquer single stage, Dupont Acrylic Laquer Base/Clear, Dupont Chromasystem Base/Clear, Sikkens Urethane, Akso Nobel (U-Tech) Base/Clear,and some currently unremembered brand of "fleet" acrylic enamel. (some of this goes back 15 years). All previous paint done with traditional siphon feed high pressure guns.
Thursday is supposed to be a 75 degree sunny day. I'll try an additional 5% reduction and adjusting the gun per Ax's post. I'll also start with a test panel. I'll wet sand out the sunroof and use that. Thanks again. jmd_forest |
Let us know how you make out.
So, in this case you are only unfamiliar with equipment and product, AH! we will get to bottom of this, it might be a conbination of both.
Yes, unfamiliar with both equipment and product. What am I gonna do? I paint so infrequently (1 car every 4-5 years, and a couple panels every year or so) that much changes between instances. I'd have used my old pressure siphon gun but it started intermittant spitting for some reason and the world seemed to be going gravity feed HVLP.
I taped out the car today and will be shooting tomorrow. As I mentioned earlier, I turned the fluid down on the gun to help control runs and as a result wound up moving the gun pretty slowly to keep a wet edge. Since ti will be warmed tomorrow, I'll adjust the gun per Ax's post and probably be moving faster, Hopefully the warmer weather will help evaporate the reducer faster and take car of the runs. jmd_forest |
Get some cheap mis-matched paint similar to what you have and practice on an old fender first. It's not easy to paint, it takes a lot of practice. Even painters with years of experience often have problems when switching paint brands. Sometimes a guy with 20 years experience has problems with the same material that he's been using for a long time. It's not reasonable to expect yourself to get it right the first time after watching a video.
Most paint (at least in low VOC areas) needs to be reduced more than they recommend on the can. They recommend that amount of reduction because that amount allows the manufacturer to meet the VOC regulations. |
I followed the tips above but still wound up with an absolute unmitigated disaster. I put a light coat on top of the sanded out test panel and that went well so I started working on the car body. I put on a light first coat from a further distance (12-16 inches or so) that seemed to smooth out well and let it flash for the recommended 15 minutes. I could tell the 2nd coat was not going as well for some reason and to top it off I tripped on the air line and the lid popped off the gun and paint splashed all over the driver's side fender. (but no other body panel). Let it flash for 15 minutes and put a third coat on everything but the DS fender. Much orange peel all over the place. Guess I'll wait a day or 2 for it to harden and wet sand it out.
Either I bite, the gun bites, the paint bites, or all three.I'm going back to the pressure siphon gun. I spent several hours cleaning out the gun and that fixed the spitting. I compared the guns side by side and the pressure gun definitely atomizes the paint better (or at least with me working the guns). Time for several beers and much crying. jmd_forest |
Man I am sorry to hear. I'm with you, I'd use the conventional gun. If things still go wrong, I'd suspect the paint and or surface. What do the directions say about application? How many and what type of coats?
You get it!!! |
Sorry to hear about your frustating times with this project, What was different between the test panel and the car?
Application instructions say 2-3 medium wet coats or until full hiding is achieved. The difference between the test panel and the car is that I had painted the test panel last week with minor orange peel results. I wet sanded it out with 320 followed by 600 and put on a single light coat. It didn't need to hide the new primer or old paint. Without a doubt, if there was any surface contamination anywhere on the car there isn't any more. I wet sanded out the hood and a bumper (both are off the car and had minor OP from my previous attempt.) and will try and reshoot these today using the old gun. I'll let the car harden up another day or 2 before wet sanding it out.
Had to order another gallon paint kit, I don't have enough paint to redo the entire car. Hopefully I'll finish the car next week if we get some 70+ degree weather (and the old gun give me decent results.) jmd_forest |
Well...shot the hood and bumper with the old gun today. It came out better than the car body but still had "orange peel". Actually, it's more like HUGE OP (1/8 " or so) dimples under a glossy surface. I've been reading on the web regarding this and similar cheap AE paints and the consensus seem to be to really thin it out as low as 4:2:1. I read the Dupont Centari AE spec sheet and they recommend 3:1:1. Never again with the cheap paint!! I was just afraid of applying the urethane over the MAACO AE and I really didn't want to strip the body on a $1500 car. This was supposed to be quick and easy.
At least I got 3 medium wet coats on with no runs and should be able to color sand it smooth and buff it glossy I'm going to try a much thinner reduction on a single car panel once I get the new paint in and see how it goes. jmd_forest |
Ax will know better than I but I don't think there would have been any issue with going over Maaco's paint with urethane. Moot point though. Yes thin the crap out even further till it lays down. Then call and complain!! Please show us pictures when it's all said and done.
Spent 6 hours today wet sanding out the OP on the body. Took it down with 320 grit and dishsoap in a bucket of water and a hose. My 16 yr old son (whose car this is going to be) spent about 4 hours with me sanding also. My fingerprints are gone. Pictures are below.
http://i256.photobucket.com/albums/h...t/pc170020.jpg You can see the front fender where I tripped and splashed the paint has been aggressively sanded out. I'll need to apply a coat of primer and wet sand before painting again. As a side note, the driver's side rear corner panel had been crushed in and the driver's side door had a strange split in the metal above the door handle. I hammered out the quarter panel and reinforced and brazed the door before bondoing it smooth. The body work actually came out perfect. http://i256.photobucket.com/albums/h...t/pc170021.jpg I'm going to try and find a local painter to take a look and see if he can provide some guidance but I don't have much hope since I suppose they would want me to bring in the car for them to shoot. Maybe I'll find a sympathetic ear. jmd_forest |
Now that you don't have any more fingerprints, what about getting some decent paint to try it with, all this work deserves a good finishing. |
I've had more than one instance in the past where I unknowingly painted lacquer over acrylic enamel and it crazed/lifted and I had to strip the whole car. Way way too much work for this project so I wanted to be sure it wouldn't happen and chose the AE paint. If I was confident that a urethane wouldn't lift eiither the old paint or last week's AE I applied I would think about it. On the other hand, since I finished up the original gallon of paint I ordered another gallon kit a few days ago (Wish I hadn't done that).
It's killing me since I previously (20 years ago) painted a 69 911 Targa and a 68 Jaguar XKE 2 door coup with the cheapest fleet red AE I could find and they looked absolutely great when done; not a run, no OP, just a great looking job. 15 years ago I painted my wife's Toyota 4-Runner with Dupont Centari AE and again it came out great also. I'm coming to the conclusion that this paint sucks and I've lost a step or 2. jmd_forest |
What color is that? Guards Red?
I'm with Ax, you've done to much work and body work not to put a quality paint job on it, (like you were trying to do). Let me know what color it is and maybe I can help with the paint. |
| All times are GMT -8. The time now is 09:33 PM. |
