Stripping a car
How much of the paint can you remove with chemical strippers. I have my car almost stripped but it seems to be pretty much impossible to clean out the small crevices. I'm thinking that I need to finish off with a little localized bead blasting?
Robert Currently Porsche less (but the wife has 2) |
Warren Hall Student
A wire brush and some Mapp gas should do the trick. Just burn the paint and then brush away.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Thanks, I'll give that a try, a lot less messy than the blaster
