Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Tips for cleaning out interior (padding/glue) prior to painting?
Those of you who cleaned out your interiors of the glue and padding residue, what is the secret? I tried adhesive remover, Goof Off, and while they work, they only work after a LONG time and a lot of chemicals, plus a few towels.
Do I need to really clean through every bit of this before painting, and if I paint, can I do some rustoleum from a spray can or do I have to go pro?
I don't need it for weight reduction, but rather for aesthetics
'00 Boxster, V4 (POC)
2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
Old 05-14-2008, 06:36 PM
