soft top part replacement
Does anyone know where i can find the weather striping shown (circled) in the following picture? or a place in San Diego that can do the replacement?
It is worn to the point where the window does does not sit again it, thus the wind noise when the top is up. It appears that the piece can be taken out. http://forums.pelicanparts.com/uploa...1212990670.jpg |
our friendly and gracious host appears to sell them....#94 on this link.......
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BDYsl4_pg3.htm Hope this helps..:D Gregg S |
If the underlying rubber is OK, and just the covers are bad, you can remove the parts, hopefully without snapping off the little studs that hold it in place, they can be recovered for a lot less than buying new. Once recovered, they can be adjusted to seal against the door glass once again. I did this when I replaced my entire cab top fabric and rear window sections a few years ago. They still look and seal like new. Good luck!! Tony.
| All times are GMT -8. The time now is 07:51 PM. |
