-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Bolt size for securing rear wing to trunk lid (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/419984-bolt-size-securing-rear-wing-trunk-lid.html)
ChkbookMechanic 07-15-2008 05:23 AM
I have a '84 911 Carrera with a whale tail and the whale tail is not secured across the rear of the trunk lid (gotta love POs). I see that there are 5 screw / bolt holes already drilled to secure it, but I don't know the sizes of bolts and washers I should buy to secure it.
After some trial and error I think I can use a 4mm bolt/nut/washer combination to secure it however I'd like to know for sure if this is the correct hardware to use or not.
ChkbookMechanic 11-21-2008 07:56 PM
I figured I'd update this since I finally got around to fixing the wing... Happened when I pulled off the wing the lip where the screws / bolts go into had been chipped and broken off. I had to re-fiberglass the lip then drill holes into it.
I just used some small bolts and washers to hold the rear of the wing to the deck lid.
