-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Painting a Helmet (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/423252-painting-helmet.html)
ncseahawk 08-03-2008 10:39 AM
Painting a Helmet
Anyone here ever paint a helmet?
I am thinking of projects for the winter...
Heel n Toe 08-24-2008 01:01 PM
I've never done it, but if you have any experience at all with masking, etc. you shouldn't have much of a problem. I assume you're thinking of some sort of design.
I would recommend wet sanding the whole surface with 10K grit paper, then wiping it clean with a lint-free cloth before beginning.
Then after you finish your design, put several light coats of clear on it.
rvanderpyl 08-26-2008 07:07 AM
I would check with the manufacturer first to see what paints you can use, some may have an adverse affect on the integrity of the helmet if it isn't just a fiberglass or carbon fiber construction.
gassy 09-17-2008 02:14 PM
Kinda the same...I painted my son's batting helmet--3 light coats and then 4 light coats of clear--looks good...
aftermath 09-19-2008 11:09 AM
Very important ! Some paints have solvents and should NOT be used on a helmet. Make sure you dont cause a safety problem.
As mentioned above !
cashflyer 09-21-2008 02:18 PM
Some people use automotive paint that is suitable for use on fiberglass.
Most helmet manufacturers recommend that you not paint the helmet because they cannot take the risk of somebody using a solvent based paint that may weaken the structure.
An alternative is the many water borne automotive paints on the market now. I would stick to them, unless the helmet is just going to be used for decoration.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
