Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
ncseahawk's Avatar
Painting a Helmet
Anyone here ever paint a helmet?
I am thinking of projects for the winter...
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 08-03-2008, 10:39 AM
Run smooth, run fast
Heel n Toe's Avatar
I've never done it, but if you have any experience at all with masking, etc. you shouldn't have much of a problem. I assume you're thinking of some sort of design.
I would recommend wet sanding the whole surface with 10K grit paper, then wiping it clean with a lint-free cloth before beginning.
Then after you finish your design, put several light coats of clear on it.
- John
Old 08-24-2008, 01:01 PM
I would check with the manufacturer first to see what paints you can use, some may have an adverse affect on the integrity of the helmet if it isn't just a fiberglass or carbon fiber construction.
Robert
Currently Porsche less (but the wife has 2)
Old 08-26-2008, 07:07 AM
Registered Loser
gassy's Avatar
Kinda the same...I painted my son's batting helmet--3 light coats and then 4 light coats of clear--looks good...
Old 09-17-2008, 02:14 PM
aftermath's Avatar
Very important ! Some paints have solvents and should NOT be used on a helmet. Make sure you dont cause a safety problem.
As mentioned above !
theamsoilguy@hotmail.com
Old 09-19-2008, 11:09 AM
Bill is Dead.
cashflyer's Avatar
Some people use automotive paint that is suitable for use on fiberglass.
Most helmet manufacturers recommend that you not paint the helmet because they cannot take the risk of somebody using a solvent based paint that may weaken the structure.
An alternative is the many water borne automotive paints on the market now. I would stick to them, unless the helmet is just going to be used for decoration.
Old 09-21-2008, 02:18 PM
