Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Bug Eating Member
frogger's Avatar
Ducktails
I have a ducktail collecting dust in the garage and one of these days I'd like prep and paint it for use on my early 911. As it stands right now, the tail has gaps on each side that are about 2X that of the normal 911 panel gaps when test fitted. Is it reasonable to build this up somehow to achieve consistent panel gaps, and, if so, should I do this with polyester (e.g., Bondo), or should I strip down the gelcoat on the sides and build up with fiberglass? I looks like what ever approach I use, the effort to make this look right is going to be substantial. What do you guys think? Thanks.
Old 12-06-2007, 12:24 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I would like to see how you handle this process...post pics when you can. I wish I had a good answer for you. in my pea brain, I see two options
1. Build up the edges
2. Cut the tail right down the center and add glass there
good luck
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 12-06-2007, 01:16 PM
Bug Eating Member
frogger's Avatar
I never thought of #2, Kemo. It's a very interesting idea. I need to spend some quality time with my West System fiberglass repair booklet.
Old 12-06-2007, 02:34 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Have you ever considered bonding the upper section of the tail to a steel lid? It is a great way to cure all the gap and fit issues.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 12-06-2007, 03:52 PM
Bug Eating Member
frogger's Avatar
Kevin, that sounds great, but I'm less confident in my ability to do that nicely.
Old 12-06-2007, 04:18 PM
Jeff Alton's Avatar
Cutting itin half will widen the area the grill sits in as well.....
Cheers
www.turn3autosport.com
Old 12-06-2007, 07:50 PM
haycait911's Avatar
I've been thinking about the bonding a duck to a steel lid approach. I'll try it one of these days.
to build up your duck edges you could add more glass ( time consuming) or use a short strand fibergass filler. or, best yet, build edge with short strand, bevel back into existing glass, thin edge slightly, and wrap your new edge in fiberglass cloth. then finish with polyester filler ( bondo).
Old 12-06-2007, 09:15 PM
I would love if someone would step up and host an online class on how to build a ducktail lid out of a stock metal lid. I would join in as I have an extra stock lid I could use. Any teachers up to it?.........Garry
Old 12-07-2007, 01:48 PM
1.367m later
KevinP73's Avatar
I know I have posted pics of the process somewhere here on PP. It was a long time ago so they might be hard to find. Let me look this weekend and see if I can find the pictures on my computer. I'll post them again if I can find them. Otherwise I'll do another one and share with the class.
Old 12-07-2007, 02:01 PM
Bug Eating Member
frogger's Avatar
Great!
Old 12-07-2007, 02:27 PM
Marglass is your friend, very user fiendly.
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT"
http://axiom-motorsports.com/
Rudy Ruano, Operations Manager.
Joseph Toliva, guy who signs my check
Old 12-08-2007, 05:05 PM
I mean friendly.
Old 12-08-2007, 05:06 PM
Thanks Kevin!
Old 12-10-2007, 04:02 AM
1.367m later
KevinP73's Avatar
OK I couldn't find any pictures of the tails I've done to date so I started doing another one today. I've added a page on my site that is available now and I'll share some pictures here as I make more progress on it.
Old 12-27-2007, 08:59 PM
Work in Progress
Rich76_911s's Avatar
I know this is an old thread. But I was searching this forum to see about fiitting a ducktail and found the bonding idea interesting. So I did a search on the main forum and found the thread that Kevin was alluding to:
bb80sc/TRE/AutoInno project update
Anyone want to come over to my house and do this for me? I think it is a bit out of my league.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 08-20-2008, 07:05 PM
Friend of Warren
Way back in 2003 I posted two threads on fitting and painting a ducktail.
Prepping the tail to fit: Ducktail: Prep for Painting, Lots of Pictures
Painting the ducktail: Painting the Ducktail, Part II
Kurt V
Old 08-21-2008, 10:41 AM
