Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
galvanizing?
while chemically stripping a replacement decklid in preparation for painting,
i came upon a dull medium dark grey surface. it can be scratched.
is this galvanization?
in the areas of previous dent repair, the surface was sanded to bright metal.
i was told the donor car was a 72, i didn't think they were galvanized.
but it could be a replacement to that car.
if it is galvanization, i shouldn't sand it before priming, right?
any opinions appreciated.
Old 08-24-2008, 05:30 PM
(Former 1968Cayman)
Galvanizing can be taken off with abrasives. I'm not sure if paint stripper would affect it, but would steer clear of hard sanding until I had an answer.
1968 911P (Paperweight)
Old 08-24-2008, 06:09 PM
Hi, I had the same question when stripping my car. A shop told me it is most likely etch primer and not a galvanised piece of metal.
Elflamo
_____________________________
1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild!
Old 09-08-2008, 01:55 PM
Here is what the Galvanizing looks like. This picture was after the car was plastic media blasted. Best money spent during the restoration.
Chemical striper will not take it off. 36 grit paper on a palm sander will.
It eats paper quick and make a nice fine dust that can't be good for ya.
Silver 1980SC Euro coupe
Old 09-09-2008, 06:39 AM
Heres it is at the Blaster. Cost was a grand but if you add up your time in sanding, it was a bargain.
Plastic media will not cause panel warping.
It will save you some money if you do all the taping and covering off all the openings to keep media out of places you don't want it.I triple taped all the seams and around the window openings and had very little media where I did not want it..
Old 09-09-2008, 06:42 AM
bingo, that's what it looks like.
i won't sand it off, lite scuff then epoxy primer.
thanks
Old 09-09-2008, 10:58 AM
armandodiaz's Avatar
Can the plastic media blasting take off the rubberized undercoating? I was going to soda blast it but I heard it's not strong enough.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 09-15-2008, 04:59 PM
Tim K's Avatar
I doubt that the plastic media, or walnut shells would have any effect. I've heard that sandblasting doesn't even touch it. However if I were to try any blasting method, it would be dry ice blasting. This stuff supposedly removes gum, tar, etc.
http://video.google.ca/videosearch?q=Dry+iCe+blasting&hl=en&emb=0&aq=f#q= Dry%20iCe%20blasting&hl=en&emb=0&aq=f&start=50
Tim K
Old 09-15-2008, 10:06 PM
(Former 1968Cayman)
Sand will take it off; I built a booth in my garage and blasted my car (everything except the exterior panels). The car had the undercoating in the front wheel wells and sandblasting took it off fairly easily. Easily, that is, if you remember to change the ceramic blasting tip when needed. Otherwise, it takes a loooooong time. Oops.
Old 09-15-2008, 10:49 PM
I heard sand blasting will damage the galvanized coating?
Armando Diaz
Old 09-16-2008, 06:06 AM
3.2 CAB's Avatar
That is true. Sandblasting with sand or other hard, course media, will take it off in just a short bit of time. You really have to be careful with what you blast the outer surfaces on your body panels with, so you won't knock off the zinc while doing it. A softer media like soda, plastic grains, or even walnut/pecan shells will do far less harm that the actual abrasive medias. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-16-2008, 02:36 PM
Not worried about the outer panels since, they'll all be fiberglass. My biggest concern is taking off the undercoating, without damaging the galvanize coating. I would hate to have to deal with rust 5yrs down the road.
Any suggestions on a sandblaster? Just need it for the one uses. I was looking at a cheap one at Harbor Freight for $150
Armando Diaz
Old 09-16-2008, 03:41 PM
300hp 1800lbs is the goal
pksystems's Avatar
I'm using 20-35 grit crushed glass on my car and it is going through the 42 year old undercoating. But I'm using a siphon feed blaster/30gallon 110v compressor, so I'm not shooting it with crazy psi. It will probably take me forever, but it is working
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 09-18-2008, 06:27 AM
heat soften the undercoating (almost setting it on fire---obviously with an exhaust fan running) and then scrape it off with a pull-type paint scraper. Then wire brush or sandblast. Much faster. Just be careful not to over heat metal. Overheating should not be much of an issue as the undercoating will soften very quickly with just a propane torch. Here are some before, after and really after pictures.
Old 09-19-2008, 06:23 AM
Registered speed offender
78SCRSMAN's Avatar
Subscribed!
I'm now ABSOLUTELY going to have this done!
I have mine (78SC) on a rotisserie (just the tub) and will deliver it that way. Question is... how easy/difficult is it to remove all that dust and garbage that gets into places that it shouldn't be? Mine will be the full meal deal... everything but the interior. It just doesn't need it!
Old 10-12-2009, 09:47 AM
jsveb's Avatar
subscribed.
Old 10-19-2009, 12:35 PM
