Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Alii&Maui
Jesset100's Avatar
Carbon fiber
I need some expert advice from this board. I'm looking to get a carbon fiber duck tail from Getty Design and have questions as to fitting it to the car.
I downloaded and read the FRP tips as well as How to install deck lids from Getty, and as far as I can tell the instructions are for fiberglass and not for carbon fiber.
I want the tail to be clear coated and not painted so how do I go about fitting the tail without using bondo to fill low spots and cover the carbon fiber or sanding to lower high spots without cutting into the carbon fiber fibers?
I understand how to get shut lines nice and straight, I also understand post curing/cooking but high and low spots I'm at a loss.
I've heard good things about Getty quality so I'm hoping the tail won't have problems.
Any insight is greatly appreciated.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 03-28-2009, 05:34 PM
dkbautosports.com
962porsche's Avatar
you will find in most cases only the top layer is carbon fiber and all the under layers are fiber glass . so the install will be the same as fiber glass . there is no need to clear carbon fiber the resin used has more than sufficient UV protection . but it can be doen . carbon fiber can be color sanded and buffed if needed just like you do with clear coats . to get it to sit flat on the rear lid . you will have to grind and sand the edge of the tail . sand and grind the edge so that the tool is spining to the inside or center of the tail . this helps not to get chips on the outer edge of the tail .
Old 03-28-2009, 09:22 PM
Alii&Maui
Jesset100's Avatar
A late thank you 962. It took a month of thinking about what you posted to sink into this hard head. You wouldn't happen to know the weights of the cf vs. fg duck tail?
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 05-03-2009, 05:41 PM
dkbautosports.com
962porsche's Avatar
from the ones i have had in my hands . the same ! most of the time a tail or hood is made the same way with the same resin . insted of the first layer being fibor-glass matting is carbon-fibor . i have made real carbon fiber panels . what is sold to people and what people think there getting ? i have to much to say about that ! if you like the look than get it ! if that tail was all carbon fiber then it would cost about 2000 dollars .
Old 05-03-2009, 09:07 PM
Alii&Maui
Jesset100's Avatar
Ouch! I'm not going to spend that kind of money. The reason I ask about the weight is I bought a Gary Stratton duck tail and that thing was super light but it was to fragile for me. Every time I went to close it I thought I would break it. The base was metal but the glass duck was thin.
I've had a turbo tail and that thing was heavy and built like a brick s#%t house.
I do want a ducktail but one that is made for a street car and not like Gary's that's made for a race car.
Thanks for listening
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 05-10-2009, 07:47 PM
