-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   3M Weatherstrip adhesive removal? (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/471385-3m-weatherstrip-adhesive-removal.html)
911TES 04-27-2009 09:16 PM
Any tips on 3M weatherstrip adhesive removal?
I restoring the front trunk area where the PO used the 3M product to adhere the carpet liner. Also, I'm looking for a good factory finish I bought the various Wurth primer and satin and flat black paints - I hope I can get a good match. ('69 911T)
All suggestions appreciated!
Bill
Jagshund 04-27-2009 09:44 PM
I believe most people are using the Wurth SKS(?) to match the original coating in and under the older cars. As for the adhesive removal, if you're reworking the boot and are against the idea of using chemical-based removers, I would suggest taking it off with a light abrasive and recoating the entire area at once, assuming you find the product to your liking in regards to its simliarity to the stock appearance.
rw7810 04-29-2009 12:56 PM
How about a can of 3M Adhesive Remover :) ?
http://forums.pelicanparts.com/uploa...1241034950.gif
911TES 04-30-2009 09:11 PM
Thanks Bob
Funny you mention that. I just ran across that stuff and bought some while shopping for some Wurth products. I have a long-weekend date with my gas tank and trunk restoration this weekend. I'll report back on the 3M remover - the stuff is a bit aged and hardened.
Thanks, all.
Bill
chiroracer 10-15-2009 10:42 PM
Wire brush and razor blade. gorilla snot makes great loctite for baja prepping.
Willem Fick 10-22-2009 02:58 AM
Liberally apply mineral turpentine to the adhesive and let it sit for a couple of minutes, re-applying to keep the area well wetted. After about 10 minutes the stuff will wipe off easily with a rag, without any damage to your paintwork. A bit of soapy water will remove any oily residue very easily.
BTW this also works equally for tar spots, tree sap, as well as the gunk applied around the strut-tops.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
