Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Less brakes, more gas!
euro911sc's Avatar
Rubber list?
Anyone put together a list of rubber that is typically replaced when you do a glass out doors off fenders off bumpers off repaint? I need to get my budget in place. Thanks!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 07-23-2009, 06:50 PM
euro911sc's Avatar
Bump
Michael
'13 Cayenne GTS
Old 07-28-2009, 11:24 AM
abisel's Avatar
Yeah, I did a list of rubber for my '73 project RSR, and for the most part, all parts are still available from Porsche.
Part Number, Description, Supersede to new part number, Available?, Price
911.504.115.00 Seal, Engine Compartment, Forward Y 34.44
901.504.993.21 Seal, Engine Compartment, 3-sided 911.504.111.02 Y 82.77
901.503.394.22 Seal, Fender to Cowl, 2 rqd. Y 3.82
901.505.091.20 Seal, Body to Bumper, Front Y 40.77
901.505.093.20 Seal, Body to Bumper, Left Rear Y 14.74
901.505.094.20 Seal, Body to Bumper, Right Rear Y 14.24
901.505.497.20 Seal, Body to Bumper, Center Rear Y 10.51
901.512.901.00 Seal, Engine Lid to Bumper Y 18.99
901.511.901.02 Seal, Hood to Body, Front Y 44.60
999.703.036.50 Buffer, Hood to Body/Engine Lid to Body, 4 rqd. Y 0.39
911.531.095.00 Seal, Door, Left 911.531.095.02 Y 99.60
911.531.096.00 Seal, Door, Right 911.531.095.02 Y 99.60
911.531.931.02 Seal, Door Top, Left Outer Y 8.05
911.531.932.02 Seal, Door Top, Right Outer Y 8.05
901.531.933.20 Seal, Door Top, Vent Window, 2 rqd. Y 3.02
901.531.935.20 Seal, Door Top, Left Inner Y 86.10
901.531.936.20 Seal, Door Top, Right Inner Y 86.10
901.531.937.25 Seal, Door Top Trim, Left 911.531.951.01 Y 18.47
901.531.938.25 Seal, Door Top Trim, Right 911.631.951.01 Y 18.47
911.542.905.00 Felt, Door Glass, enough for top, rear and front
of door glass frame on both doors. Y 35.59
911.541.225.00 Seal, Windshield, pre-964, for 10mm frame 911.541.225.03 Y 79.04
964.541.225.00 Seal, Windshield, 964, for 15mm frame. Y 96.51
901.545.901.21 Seal, Back Glass, pre-964 for 10mm frame 911.545.225.00 Y 98.60
901.542.921.21 Seal, Vent Window, 2 rqd Y 42.98
901.543.191.20 Seal, Rear Window, 2 rqd Y 29.69
901.543.901.20 Seal, Rear Window, Left Outer Y 83.02
901.543.902.20 Seal, Rear Window, Right Outer Y 83.02
999.911.041.00 Edging, Rear Window, Upper, 2 rqd Y 5.44
901.543.423.00 Edging, Rear Window, Forward, 2 rqd Y 3.54
901.543.493.20 Sealing Tape, Rear Window, 2 rqd Y 2.41
901.571.325.32 Seal, Fresh Air Intake Y 23.01
901.572.913.01 Grommet, Fresh Air Hose Through Body, 2 rqd Y 7.13
901.611.902.21 Ground Strap, Battery, 2 rqd Y 17.92
999.044.001.02 Wing Nut, Ground Strap, 2 rqd N 2.30
900.025.025.02 Washer for Wing Nut, 2 rqd N.011.525.8 N 0.19
901.611.311.00 Terminal, Battery Cable, Positive, 2 rqd Y 12.14
999.611.104.00 Cover, Battery Terminal, Positive Y 2.30
901.611.313.00 Cap, Battery Terminal, Positive Y 4.39
911.631.967.00 Seal, Headlight to Fender, H4, 2 rqd Y 8.57
901.504.932.20 Seal, Gas Tank Y 24.07
911.211.297.00 Gasket, Heater Valve, 4 rqd Y 5.46
999.611.918.20 Strap, Grounding, Transmission to Body Y 12.48
901.424.293.00 Boot, Shift Rod, Transmission to Tunnel Y 14.49
923.424.591.00 Boot, Handbrake Y 12.85
914.423.922.02 Boot, Clutch Cable to Tunnel Y 6.17
911.423.593.01 Boot, Throttle Cable to Tunnel Y 14.94
911.504.491.02 Seal, Smuggler Box Lid Y 18.82
911.504.933.00 Seal, Rear Wheel Housing, Left 993.504.847.00 Y 13.35
911.504.934.00 Seal, Rear Wheel Housing, Right 993.504.848.00 Y 13.35
911.503.507.01 Seal, Foam, Rear, Roof Ventilation Y 3.86
901.504.079.00 Cover, Rear, Torsion Bar, Turbo Fender,
w/ gasket, tension spring, and nut, 2 rqd Y 30.53
911.512.531.00 Washer, Rubber, Engine Lid Release Cable. Y 0.86
901.511.791.21 Washer, Rubber, Hood Release Cable Y 1.71
911.542.403.01 Seal, Felt, Door Window Frame Leading Edge, Left Y 39.00
911.542.404.01 Seal, Felt, Door Window Frame Leading Edge, Right Y 31.61
900.145.081.00 Screw, Self Tapping, for door seal felt, 30 rqd Y 0.54
999.591.009.12 Washer, for self tapping screw, 30 rqd N 0.35
999.702.076.50 Grommet, rubber, master cylinder, supply hose through trunk shelf, 4 rqd. Y 1.78
999.702.065.50 Grommet, rubber, master cylinder, supply hose through floor, 4 rqd. Y 0.68
914.355.651.00 Grommet, rubber, tunnel, brake line, 4 rqd. Y 2.05
914.355.652.00 Clamp, for tunnel brake line rubber grommet, 4 rqd. Y 0.76
914.356.201.00 Grommet, rubber, tunnel fuel return line, 4 rqd Y 4.94
911.356.202.00 Grommet, rubber, tunnel fuel line, 4 rqd. N 5.65
E 999.702.082.50 Grommet, rubber, fuel system vent hose, firewall, 2 rqd. NO GOOD#
E 999.702.083.50 Grommet, rubber, fuel system vent, canister to fender tank NO GOOD#
999.702.084.50 Grommet, rubber, brake master cylinder overflow tube NO GOOD#
901.201.591.20 Sleeve, Fender, Gas Tank Filler Neck Y 28.45
911.201.095.00 Grommet seal, inner fender, fuel tank filler tube, Y 5.75
911.201.593.00 Socket, overflow tube connector, fuel filler sleeve Y 3.94
901.201.931.00 Tube, overflow, fuel tank filler tube sleeve. 911.201.731.00 N 1.94
111.801.177 Rubber valve, floor pan, 8 rqd. Y 2.11
901.555.505.20 Vinyl lining for B-pillar, black, 2 required N 12.19
E 901.555.507.20 Vinyl lining for A-pillar, black, 2 required NO GOOD#
911.501.125.00 Support for oil line, 6 required N 4.00
901.564.905.05 Seal, Sunroof Panel, Rear, Rubber Y 11.94
911.564.193.00 Seal, Sunroof Panel, Rear, Felt Y 17.49
911.564.191.00 Seal, Sunroof, Front, Felt Y 46.72
911.564.409.00 Seal, Sunroof, Front Y 2.78
911.564.409.01 Seal, Sunroof, Sides, 2 required Y 1.04
911.356.202.03 Grommet, rubber, tunnel fuel supply line, 4 rqd. Y 1.51
999.152.004.00 Circlip, for Gas Tank Filler Neck Sleeve Y 13.57
999.591.336.01 Clip, Headliner to frame, 24 required Y 0.12
911.504.385.00 Washer, Rubber, Gas Filler Lid Release Cable Y 0.27
901.504.317.21 Cable, Gas Tank Filler Lid Y 5.03
901.552.822.00 Knob, Gas Tank Filler Lid Cable Y 10.33
901.504.385.20 Connecting Tube, Gas Tank Filler Lid Cable Y 1.66
914.504.319.00 Grommet, rubber, gas tank filler lid cable. Y 3.49
911.504.113.02 Seal, Engine Compartment, Forward Y 23.23
964.545.225.00 Seal, Back Glass, 964 for 15mm frame Y 157.09
Old 08-08-2009, 08:57 AM
seafeye's Avatar
Very Helpful. Thanks for doing that.
What me speed?
Old 07-06-2016, 09:20 AM
