-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   color sanding question (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/498559-color-sanding-question.html)
robmog 09-13-2009 07:41 AM
finished my DIY paint,
many thanks to Freddie H and his painting 101 series!
its single stage PPG, surprizingly little crap and minimal orange peel!
so now i'm getting cocky and am going for a really nice finish.
so...
when color sanding prior to buffing what grits of wet/dry should i use?
1: start with 1000, 1200 or 1500?
2: end with 2000, 2500 or 3000?
what is you preferred sequence?
thanks
http://forums.pelicanparts.com/uploa...1252852518.jpg
962porsche 09-13-2009 08:28 AM
1500 works best . also to help so the sand paper does not get pills in it . put a cap of dish soap in the wet sanding bucket . also get a good soft block and when color sanding .sand with the longest strokes you can . a short sanding stroke will sand waves into the finish .
robmog 09-13-2009 06:14 PM
just 1500?
is there any value to going to 2000 as a next step?
would that make buffing any easier?
962porsche 09-13-2009 08:13 PM
no all you need is 1500 . we use presta ultra-cutting creme and a white 100% twisted wool pad first then we go to presta's chroma 1500 or 2000 with a waffle foam ( presta's yellow) pad or you could use 3M's black foam pad .
rw7810 09-14-2009 10:35 AM
I used 800, 1000, 1500 and 2000 followed by Surefinish on a wool bonnet and a Makita polisher. You can find SureFinish here: http://www.autobodystore.com. They also have a great forum.
robmog 09-14-2009 07:23 PM
thanks guys
